Hi Team,
I’m trying to add SSL certs to my passbolt install after the fact of getting it all running.
So I’ve got my .crt and .key and added them to the /etc/nginx/conf.d/passbolt.conf and added a listen 443 ssl; statement as well and restarted nginx but i get the following issues:
- Text only came. When clicking a link I get redirected to the old http site.
- After removing the listen 80; statement from the nginx/passbolt.conf and restarting it said it was registered to another domain (http) ok understandable, so I go to re-register it and put in my private key etc and lost access. After 30 mins of trying to get it working, I rolled back to the original setup I had and re-registered and now I have access again, but of course SSL isn’t working.
Does anyone have a walkthrough on how to get this done? I’m sure this is a common task.
UPDATE:
I was able to figure out that I had to first change the
passbolt.default.php: ‘fullBaseUrl’ => ‘myFQDN’,
Then apply my changes to nginx.
Now SSL is working, however the extention no longer works. I’ve removed it and re-downloaded it but I don’t get prompted to re-register it.
UPDATE 2:
I removed the plugin. Closed all browsers and then logged back into the new https://fqdn and go prompted to download the plugin from there, which I did. Then I had to close it again and reopen the page in the browser and then I was prompted to re-register or claim my account, which I did re-claim successfully.
Hope this helps someone else.
Thanks!
