when reading the QR code in the passbolt menu everything works fine.
But when typing in my passphrase a black box without text appears at the bottom and nothing happens.
When I type in the wrong passphrase, the black box says, that I use the wrong passphrase so I’m typing in the right one when nothing happens.
Has anybody have a clue on how to fix this or by which issue it could be caused?
Thank you very much. I’ve already been fighting much with the encryption to work with the mobile app and don’t want to give up to such an error.
Regards
Healthcheck
[PASS] PHP version 7.3.31-1~deb10u1.
[PASS] Full base url is set to https://protoraspberry:443
[FAIL] App.fullBaseUrl does not validate. https://protoraspberry:443.
[HELP] Edit App.fullBaseUrl in config/passbolt.php
[HELP] Select a valid domain name as defined by section 2.3.1 of http://www.ietf.org/rfc/rfc1035.txt
fopen(https://protoraspberry/healthcheck/status.json): failed to open stream: operation failed
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.4.0).
My system
System: Raspberry Pi 4
OS: Raspbian 10
Web Server: Nginx 1.14.2
PHP v.: 7.3.31-1~deb10u1
Passbolt v.: 3.4.0
My phone
Xiaomi Mi 9 running xiaomi.eu MIUI 12.6 on Android 11 RKQ1.200826.002
