Ansible Passbolt Plugin does not handle TOTP
i have setup the ansible plugin anatomicjc.passbolt successfully and it works.
For TOTP enabled accounts, it fails with the following error:
TASK [Password lookup fetch one"] ******************************************************************************************************************************************************************************************
Loading collection anatomicjc.passbolt from /srv/tftp/webtemp/ansible/.ansible/collections/ansible_collections/anatomicjc/passbolt
fatal: [localhost]: FAILED! => {}
MSG:
An unhandled exception occurred while running the lookup plugin ā€˜anatomicjc.passbolt.passboltā€™. Error was a <class ā€˜json.decoder.JSONDecodeErrorā€™>, original message: Expecting value: line 1 column 1 (char 0)
Is there a working solution to provide the totp code in runtime for the requesting account?
Server version latest-ce (4.7.0)
Best regards and many thanks
AckDeGo
I had that same issue.
A working solution would be very welcome.
It is indeed not yet implemented. I will try to have a look in the coming days.
Hi Anatomic,
could you get a look to the passbolt-ansible-TOTP issue?
some status relating to this issue would be very appreciated.
thanks
Hi AnatomicJC,
do you have some news about that? I want to automate my Servers. there are protected with multiple passwords hosted in passbolt.
Thanks for help.
Best regards
AckDeGo
Hey there,
Unfortunately, I have no ETA about this request. It is currently not easy for me to find time to work on this.
:cry:
Hey,
thanks for your reply. Is there a chance to use an api_token to get this working without 2fa?
Idea:
  • A user has to enroll an api_token for his own user to use passbolt-ansible password plugin, to read/write passwords etc.
  • When an authentication happens over api, check if there is an working api_token for this user, if not normal authentication flow, (user with mfa has to handle the mfa).
  • To renew/enroll this specific api_token, the user has to handle this with the passbolt web interface.
  • That can help in the first step, to bypass the active mfa, like the jwt in android app.
For me, that would be fine for the first step.
