I am trying to bring a new installation of PassBolt CE via Docker online within a LAN so that we can test/evaluate the product before considering the business version.
I am able to build/run the container, and it appears to be accessible, when I follow the new user registration link, it looks like it works, I am allowed to enter my e-mail address and create a passphrase. However, after that is done, I’m redirected to a page that says “Something went wrong” “Authentication is required to continue”. At that point, it’s impossible for me to log in or access the registration page, and the system does not recognize the password that I just created.
I am using the 5.4.1-1-ce image, if that matters.
I don’t believe it’s a Docker issue, using the Passbolt Healthcheck routine tells me the following:
su -s /bin/bash -c “/usr/share/php/passbolt/bin/cake passbolt healthcheck” www-data
2025-08-26 21:54:43 warning: SplFileInfo::openFile(/var/lib/passbolt/tmp/cache/persistent/myapp_cake_translations_translations.cake_console.en_UK): Failed to open stream: Permission denied in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php on line 384
warning: 512 :: SplFileInfo::openFile(/var/lib/passbolt/tmp/cache/persistent/myapp_cake_translations_translations.cake_console.en_UK): Failed to open stream: Permission denied on line 384 of /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php
__ __ __
/ __ \__ __ __/ /_ ___ / / /_
/ /_/ / __ `/ __/ __/ __ \/ __ \/ / __/
/_/ \__,_/__/__/_.___/\____/_/\__/
If you want to have more information about the different checks, please take a look at the documentation: 2025-08-26 21:54:44 error: Record not found in table `organization_settings`.
[INFO] Linux 1fbcf02bee04 5.15.0-134-generic #145-Ubuntu SMP Wed Feb 12 20:08:39 UTC 2025 x86_64 GNU/Linux
[PASS] PHP version 8.2.29.
[FAIL] The temporary directory and its content are not writable, or are executable.
[HELP] you can try:
[HELP] sudo chown -R www-data:www-data /var/lib/passbolt/tmp/
[HELP] sudo chmod -R 775 $(find /var/lib/passbolt/tmp/ -type d)
[HELP] sudo chmod -R 664 $(find /var/lib/passbolt/tmp/ -type f)
[HELP] See `timedatectl | grep -i -A 1 clock`. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
[PASS] Full base url is set to http:172.16.10.3:3380
SMTP settings
[FAIL] A valid JWT key pair is missing.
[HELP] Run the create JWT keys script to create a valid JWT secret and public key pair:
[HELP] sudo su -s /bin/bash -c “/usr/share/php/passbolt/bin/cake passbolt create_jwt_keys” www-data
[HELP] See.
[FAIL] The server key fingerprint doesn’t match the one defined in /etc/passbolt/passbolt.php.
[HELP] sudo su -s /bin/bash -c “gpg --list-keys --fingerprint --home /var/lib/passbolt/.gnupg” www-data | grep -i -B 2 ‘SERVER_KEY_EMAIL’
[HELP] See. install#toc_gpg
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c “gpg --home /var/lib/passbolt/.gnupg --import /etc/passbolt/gpg/serverkey_private.asc” www-data
[PASS] Using latest passbolt version (5.4.1).
[HELP] Check App.fullBaseUrl url scheme in /etc/passbolt/passbolt.php.
[PASS] 34 tables found.
Metadata
[FAIL] 11 error(s) found. Hang in there!
So, there appears to be a lot of issues with permissions in the Docker image itself, which can be corrected, although unfortunately then they’ll return the next time the container is restarted.
I haven’t gotten to the stage of even trying to mess with implementing HTTPS yet, since this is still a test installation, so I’m not really concerned about them. We’ll worry about SSL/TLS after the platform is working.
I don’t know why the image reports this, nothing in the installation documentation references setting up NTP in the Docker yaml file.
There again, it’s a Docker image, nothing in the install documentation refers to setting a config file. Maybe there are additional instructions required for running Passbolt in Docker?
The warnings about SMTP don’t seem to be serious, and the running container is capable of sending e-mails , so that’s probably not a critical issue.
I suspect that these messages about keys/keypairs are the root cause of the site being non-functional:
I had been following the instructions at this link for how to install and run Passbolt-
https://www.passbolt.com/docs/hosting/install/ce/docker/
I am now realizing, these instructions cover maybe 10% at best of the actual required steps to install Passbolt, is there any more complete documentation available?
Alternatively, is the Docker implementation of Passbolt considered to be viable for production use, or should I stop trying to run it in a container and do a full local install in a virtual machine?
