Connection refused
I am trying to do an email notification test but getting a connection refused error.
I have entered by SMTP server IP address and other required details.
What could I be missing here?
Have you checked the information you provided is correct on a mail client like Outlook or Thunderbird?
Do the logs give you any extra information?
The machine running Passbolt has access to the machine where the mail server is running?
The SMTP server is actually is on the same network as Passbolt - I have also tested email delivery which looks okay.
Have you tried the same config on a mail client and it works?
Maybe you forgot some parameters on your config. Can you paste the config masking the info?
