on the login page I get:
Could not verify server key. There was an error during authentication. Enable debug mode for more information
Different Server Key? Possible to recover?
do I need to setup a volume in /var/www/passbolt/config/gpg?
see here for more info about my deployment
gpg: directory '/home/www-data/.gnupg' created
gpg: keybox '/home/www-data/.gnupg/pubring.kbx' created
gpg: /home/www-data/.gnupg/trustdb.gpg: trustdb created
gpg: key B4B726271B6F18AF marked as ultimately trusted
gpg: directory '/home/www-data/.gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/home/www-data/.gnupg/openpgp-revocs.d/FB5FC8E038D89A0F1A9D8008B4B726271B6F18AF.rev'
gpg: key B4B726271B6F18AF: "Passbolt default user <passbolt@yourdomain.com>" not changed
gpg: unchanged: 1
gpg: key B4B726271B6F18AF: secret key imported
gpg: unchanged: 1
gpg: secret keys read: 1
gpg: secret keys unchanged: 1
Generating a 4096 bit RSA private key
writing new private key to '/etc/ssl/certs/certificate.key'
gpg: checking the trustdb
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 0 trust: 0-, 0q, 0n, 0m, 0f, 1u
Running migration scripts.
using migration paths
- /var/www/passbolt/config/Migrations
using seed paths
- /var/www/passbolt/config/Seeds
using environment default
using adapter mysql
using database passbolt
All Done. Took 0.0054s
using seed paths
Writing dump file `/var/www/passbolt/config/Migrations/schema-dump-default.lock`...
Dump file `/var/www/passbolt/config/Migrations/schema-dump-default.lock` was successfully written
Enjoy! ☮
/usr/lib/python2.7/dist-packages/supervisor/options.py:298: UserWarning: Supervisord is running as root and it is searching for its configuration file in default locations (including its current working directory); you probably want to specify a "-c" argument specifying an absolute path to a configuration file for improved security.
'Supervisord is running as root and it is searching '
2018-08-09 07:14:41,349 CRIT Supervisor running as root (no user in config file)
2018-08-09 07:14:41,360 INFO RPC interface 'supervisor' initialized
2018-08-09 07:14:41,361 CRIT Server 'unix_http_server' running without any HTTP authentication checking
2018-08-09 07:14:41,361 INFO supervisord started with pid 64
2018-08-09 07:14:42,362 INFO spawned: 'php-fpm' with pid 67
2018-08-09 07:14:42,364 INFO spawned: 'nginx' with pid 68
2018-08-09 07:14:42,366 INFO spawned: 'cron' with pid 69
[09-Aug-2018 07:14:42] NOTICE: fpm is running, pid 67
[09-Aug-2018 07:14:42] NOTICE: ready to handle connections
2018-08-09 07:14:43,437 INFO success: php-fpm entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2018-08-09 07:14:43,437 INFO success: nginx entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2018-08-09 07:14:43,437 INFO success: cron entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
127.0.0.1 - 09/Aug/2018:07:17:38 +0000 "GET /index.php" 302
127.0.0.1 - 09/Aug/2018:07:17:38 +0000 "GET /index.php" 200
