Hi all, trying to get Passbolt up and running to check it out but having some issues with the latest Docker image.
I’ve followed the instructions on the Docker install page but having some odd issues.
- It doesn’t appear that PHP starts when the Docker container starts nor does it appear the service is installed? I’m able to shell into the server and start Nginx (which appears to have to be manual? Doesn’t auto-start?) But when looking for the PHP service I’m not seeing it. What might I be missing?
2018/12/31 18:11:43 [error] 43#43: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.17.0.1, server: , request: “GET / HTTP/1.0”, upstream: “fastcgi://127.0.0.1:9000”,
This is from the nginx logs on the container when trying to make a request.
The other issue I’m having is it doesn’t appear to install? Maybe this is done via the web once I’m able to access this but it also appears it would install via the /docker-entrypoint.sh? Maybe?
So after following the steps on https://help.passbolt.com/hosting/install/ce/docker when I try to create the initial user I’m getting an error that the database table for users doesn’t exist and if I look in the db, sure enough no tables have been generated.
Am I missing something?
Steps to reproduce for me are to just follow the commands on the https://help.passbolt.com/hosting/install/ce/docker running on Debian 9 (fresh server install) running the latest stable Docker CE
