Docker migration from 3.5.0 to 4.1.0-1 cause gpg error
Hello !
I’ve update my passbolt from 3.5.0. to 4.1.0-1 using docker and now it doesn’t start. When checking the log here what I obtain :
gpg: key AAAAAAAAAAAAAAA: public key "Passbolt default user <passbolt@yourdomain.com>" imported
gpg:               imported: 1
gpg: key AAAAAAAAAAAAAAA: "Passbolt default user <passbolt@yourdomain.com>" not changed
gpg: key AAAAAAAAAAAAAAA/AAAAAAAAAAAAAAA: error sending to agent: No such file or directory
gpg: error building skey array: No such file or directory
gpg: error reading '/etc/passbolt/gpg/serverkey_private.asc': No such file or directory
gpg: import from '/etc/passbolt/gpg/serverkey_private.asc' failed: No such file or directory
gpg: Total number processed: 0
The AAAAAAAAAAAAAAA is for masking values
I’ve changed the docker entrypoint to “tail -f /dev/null” to be able to enter the container (otherwise it keep crashing) and here is the permissions :
The healthcheck :
 [PASS] PHP version 7.4.28.
 [PASS] Full base url is set to https://password.frequencebanane.ch
 [PASS] 32 tables found
 [HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt install" www-data
 [HELP] you can try:
 [FAIL] This installation is not up to date. Currently using 3.6.0 and it should be v4.1.2.
 [FAIL] 6 error(s) found. Hang in there!
I’ve tried :
But it changes nothing… Any idea ?
My passbolt storage is on a NAS using NFS but as you should see the permission seems correct…
Best regards :slight_smile:
Does anyone has an idea ?
I’m still stuck with it
Even removing the mount of gpg key failed (in that case passbolt display that the entropy is too low)
Also if i manually import the key ( gpg --batch --import serverkey_private.asc) then launch the healthcheck it seems to pass. But when I restart the container the effect cannot persist…
Ok it seems related to NFS, even with the permission shown below, it doesn’t work from NFS target but works if I mount from the host :confused:
Maybe you can try to send your gpg server keys as Docker secrets. Here is the documentation:
Also, remember to give to docker the environment variables of fingerprint and email
I was thinking of that but secrets are only mounted to a specific path in the container, /run/secrets/secretname so If I don’t have a way to change the behavior of passbolt and to make it look to this place it wont work
