Email settings appear empty after upgrade to 5.14 CE from 5.13.4 CE
Hi Community,
I recently Updated my passbolt instance from 5.13.4 CE to 5.14 CE and I noticed that when I opened the settings for my email server configuration it was empty. Although after doing the Upgrade I received emails as normal. I had setup MailGun as my provider. I love the support for more email providers that has been added and the new UI.
This occurred only after I opened the settings page.
Even though it shows nothing is configured I still receive emails without any issue.
OS - Ubuntu 24.04.4 LTS
PHP version - 8.5.9
//    _,///./_//__/
If you want to have more information about the different checks, please take a look at the documentation: https://www.passbolt.com/docs/admin/server-maintenance/passbolt-api-status/.........................
[INFO] Linux passboltsg2 6.8.0-134-generic #134-Ubuntu SMP PREEMPT_DYNAMIC Fri Jun 26 18:43:11 UTC 2026 x86_64 x86_64 x86_64 GNU/Linux
[PASS] PHP version 8.5.9.
[INFO] gpg (GnuPG) 2.4.4 / libgcrypt 1.10.3
[PASS] System clock is synchronized and NTP service is active.
[PASS] Full base url is set to https://pbolt.rlab.win
SMTP settings
[PASS] The SMTP Settings plugin endpoints are disabled.
[PASS] Using latest passbolt version (5.14.0).
[PASS] The edition served is CE.
[PASS] 53 tables found.
[PASS] The database version is supported.
[PASS] The model schema cache shows no discrepancies with the database schema.
Metadata
[PASS] The server does not have access to the server metadata private key in Zero-knowledge mode.
[PASS] No error found. Nice one, sparky!
Hi 2Face,
Thanks for the detailed report and healthcheck output,
In your healthcheck, interestingly I see “The SMTP Settings plugin endpoints are disabled”, which means that the settings are from passbolt.php and not UI (database). Also, it means that the endpoint is disabled and therefore, you can’t edit the settings from the user interface which can potentially lead into this weird behavior.
As I mention, it’s because your SMTP configuration was set directly in passbolt.php rather than through the UI. We recommend using the UI version since the settings will be encrypted with your server public key in the database, and it prevents on the settings from file.
Potentially, what could solve the issue could be:
  • In your passbolt.php you should have passbolt.security.smtpSettings.endpointsDisabled set to true, you can change this value to false.
  • Then go to the administration settings in the UI and re-enter your MailGun configuration there, and save.
  • Send a test email to confirm it’s working.
    • What you can double check also is by running this SQL query: SELECT * FROM organization_settings WHERE property = "smtp"\G you should see a pgp message.
  • Once confirmed the settings are saved in the database and confirmed working, except if you really have a reason to block the smtp endpoint, you can revert the settings back to true.
Let me know if the settings page still appears empty after this, hope this will help.
Thomas,
Hi Thomas,
Thank you for your help.
Yes I remember disabling the SMTP endpoint somewhere around version 5.10 - 5.12.
But I distinctly remember configuring the email settings from the Web UI and not the config file.
I just checked the config file and yes SMTP endpoint is disabled but there are no credentials for the email server set up in the config.
Edit 1:
I just ran the DB query you provided and yes SMTP settings are stored in the DB
Hi 2Face,
Thanks for your reply, let’s dig a bit further.
Could you check the console logs? Open the browser console in the extension (right-click the extension icon > Inspect, or via the debug/developer tools) to see if any error is thrown when the page tries to fetch the SMTP configuration? That will tell us more about the issue.
Also, one thing worth checking: have you rotated your server’s GPG key since you first configured the SMTP settings through the UI? Since those settings are stored encrypted in the database with your server’s public key, a key rotation would explain why they now appear empty (the app can no longer decrypt what was stored).
If you haven’t rotated the key, could you try setting passbolt.security.smtpSettings.endpointsDisabled back to false in passbolt.php, save, and then re-enter your SMTP configuration through the UI and save. If you don’t see any errors, the settings are saved and your emails keeps working, you should be able to turn the settings back to false. In case you face an error, can you please share any output that could help me investigating further?
Thanks,
Thomas
Hi Thomas1!
You mentioned “We recommend using the UI version since the settings will be encrypted with your server public key in the database, and it prevents on the settings from file.” but when you run a health check from UI under SMTP comfiguration section if the endpoints are not disable you will get an alert sugesting to disable this.
What should be the recommended way to configure this?
Thanks!
BR.
Pablo.
Hello pegimenez,
Hope your doing good.
Yes that’s right, what we recommend is using the UI because its goes directly in the database. But as it is an open endpoint we still need to put a warn on it, if you are sure the smtp setting won’t move you can put back “passbolt.security.smtpSettings.endpointsDisabled” to true to have the check passing again. Hope this clarify things.
Thomas
Hi Thomas1,
Sorry for the delay.
I see there is one error in the console when I open the Email Server config.
Hello 2face!
Hope you had a great week-end!
Could you please try setting “passbolt.security.smtpSettings.endpointsDisabled” to false. Then, you should be able to enter your settings in the UI and save it. As mentioned in our documentation (in the red danger box) if you are confident that the SMTP settings won’t move you can iterate afterwards on “passbolt.security.smtpSettings.endpointsDisabled” to true.
Now, regarding the error in the console, I’m a little bit surprised that you run into this issue, I’ve seen similar behavior of this case after a server key rotation where the encrypted message can’t be decrypted anymore since it was encrypted with the old key. Have you recently rotated your server keys?
Tell me how its goes, have a great day.
Best regards,
