[x] I have read intro post: h ttps://community.passbolt.com/t/about-the-installation-issues-category/12
I’m getting ‘The OpenPGP server key defined in the config could not be found in the GnuPG keyring.’ on login page.
Healthcheck shows no errors:
sudo su -s /bin/bash -c "./bin/cake passbolt healthcheck" apache
Healthcheck shell......string(28) "ENV: / usr/share/httpd/.gnupg"
[PASS] PHP version 7.2.14.
[FAIL] Debug mode is on.
[PASS] Full base url is set to https://passbolt.break-media.net
[PASS] 18 tables found
[PASS] The environment variable GNUPGHOME is set to /usr/share/httpd/.gnupg.
[PASS] The directory /usr/share/httpd/.gnupg containing the keyring is writable by the webserver user.
[PASS] Using latest passbolt version (2.5.0).
I added some debug lines to GpgAuthenticate::_initKeyring():
$this->_gpg = new \gnupg();
$info = $this->_gpg->keyinfo($keyid);
$this->_gpg->seterrormode(\gnupg::ERROR_EXCEPTION);
var_dump($this->_gpg->geterror());
Error is: ‘could not init keylist’.
Configuration is Centos 7, php7.2, php-fpm, apache2.
In both ways (cli and fpm) script is executed from ‘apache’ user.
/usr/share/httpd/.gnupg is writable and with SELinux permissions
getenv(‘GNUPGHOME’) is /usr/share/httpd/.gnupg in both ways
‘sudo ausearch -m AVC,USER_AVC -ts recent’ returns
GPGme Version => 1.3.2 for both cli and fpm
gpg --version
gpg (GnuPG) 2.0.22 libgcrypt 1.5.3 Copyright (C) 2013 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Home: ~/.gnupg Supported algorithms: Pubkey: RSA, ?, ?, ELG, DSA Cipher: IDEA, 3DES, CAST5, BLOWFISH, AES, AES192, AES256, TWOFISH, CAMELLIA128, CAMELLIA192, CAMELLIA256 Hash: MD5, SHA1, RIPEMD160, SHA256, SHA384, SHA512, SHA224 Compression: Uncompressed, ZIP, ZLIB, BZIP2
What else I forgot to check?
