HTTP ERROR 500, Healthcheck
Hello, After upgrading passbolt I’mfacing problem regarding heathcheck status:
// _,///
./_//__/
If you want to have more information about the different checks, please take a look at the documentation: Environment
[INFO] Linux pb 5.15.0-185-generic #195-Ubuntu SMP Fri Jun 19 17:11:50 UTC 2026 x86_64 x86_64 x86_64 GNU/Linux
[PASS] PHP version 8.4.23.
[INFO] gpg (GnuPG) 2.2.27 / libgcrypt 1.9.4
[PASS] System clock is synchronized and NTP service is active.
[PASS] Full base url is set to https://passbolt.gse.com.ge
SMTP settings
[PASS] Using latest passbolt version (5.13.0).
[PASS] The edition served is CE.
[PASS] 53 tables found.
[PASS] The database version is supported.
Metadata
