We are a small team and try to limit the number of options (e.g. multiple distributions multiplied by webserver choice) in the documentation for installing passbolt, as it create support overhead. This may change as the team grow.
@Remy You are right and in the end it was my fault that I did not read the line in the second paragraph “Create a web server matching the system requirements.”. I would recommend just two small changes:
old
System requirements
Any Unix-like major distribution (Debian, Centos, Ubuntu, *BSD)
note: Passbolt can also operate on a separate “http only” webserver backend with a separate https termination point (reverse proxy) like Nginx or Haproxy in front
In the apache world (and also in other webservers deriving from apache like ibm’s websphere) mod_rewrite is not always included from the start. Therefore it makes sense to put that point more prominently into the req list.
