Kdbx import error Argon2 not implemented
Hi there,
I am currently evaluating passbolt as a trial period and cannot get KeePass files imported.
When using the import and selecting a *.kdbx file i get an error.
Error Message:
There was an unexpected error…
Error NotImplemented: Argon2 not implemented
Systeminformation:
passbolt trial license
installation based on the ova image
So far i tried to update my KeePass Instalaltion (from 2.44 to 2.47), Saving the *.kdbx with new version, same error.
Am I right that there is a specific package missing in the debian install? If so please tell me the needed install steps/packages.
Thank you in advance
EDIT:
Is this connected to the format of the kdbx file using Folders? I see that the sample kdbx file has none.
Found the Solution:
KeePass itself is offering different Key transformation settings.
In KeePass go to:
File → Database Settings
Security Tab
Key Transformation Section
Key derivation function: Argon2d
Change the Setting and save the database. Import works just fine.
Please Close
Hello @CNNS,
Thank you for the report.
We are well aware that argon2 is not yet supported. This item our on roadmap and we’ll keep the community posted when it is released.
