Login page with Multi fields
I have a multi fields login page - I have to entre 4 fields before entering in the application.
I have update all information in the passbolt entry, but these informations are not imported in fields automatically.
Do you have a tips to do this ?
Hello GaetDout,
Just to be sure, how did you store the 4 values? Did you use the custom fields feature?
For now the workaround would be to add custom fields in your password resource. To create custom fields:
  • Click on your resource.
  • Click on edit.
  • Click on “Add secret” and “Custom fields” as shown below.
Then, you can copy it from your passbolt UI to your login page.
We also have a feature that will come in the mid-term (ref. PB-54715) that will allow you to copy your custom fields directly from your quick access so you wouldn’t need to go to the passbolt UI to copy them.
Hope this will help.
Have a great weekend!
Thomas.
Hi Thomas,
Thanks a lot for your answer.
I already add multiple custom fileds.
I’ll be very interested by th PB-54715 !
