Logs showing internal IP instead of X-Forwarded-For IP
Hi, Sorry if this has been answered somewhere else. I haven’t been able to find a topic that matches this issue.
I recently noticed on my Passbolt CE install that the logs use the internal IP of the docker network instead of the X-Forwarded-For IP.
When I went through the environment variables I noticed I could set PASSBOLT_SECURITY_PROXIES_ACTIVE to true, which, to my understanding, should tell Passbolt that it is behind a proxy and to use the appropriate HTTP Headers.
Yet, it is still writing the logs with the internal IP of the Traefik proxy. The main issue here for me is that the emails being sent also show the internal IP in the User IP: section of the mail.
Is there something obvious that I have missed? I tried a clean install following the docker automatic cert setup with traefik, yet I got the same result.
Let me know if you need anything else.
OS: Rocky Linux release 9.4 (Blue Onyx)
*Actual domain name has been switched out with domain.com
Passbolt Compose file (Traefik is moved to separate file, as it was already in use):
  db:
    image: mariadb:10.11
    restart: unless-stopped
    networks:
      - internal
      MYSQL_DATABASE: "passbolt"
      MYSQL_USER: "passbolt"
      MYSQL_PASSWORD: "P4ssb0lt"
    depends_on:
      - db
    networks:
      - internal
      - traefik_public
      APP_FULL_BASE_URL: https://passbolt.domain.com
      PASSBOLT_SECURITY_PROXIES_ACTIVE: true
    command:
        "/usr/bin/wait-for.sh",
        "-t",
        "0",
        "db:3306",
        "/docker-entrypoint.sh",
    labels:
      traefik.enable: true
      traefik.http.routers.passbolt-http.entrypoints: http
      traefik.http.routers.passbolt-http.middlewares: "SslHeader@file, cloudflare@file"
      traefik.http.routers.passbolt-https.middlewares: "SslHeader@file, cloudflare@file"
      traefik.http.routers.passbolt-https.entrypoints: https
      traefik.http.routers.passbolt-https.tls: true
  database_volume:
  gpg_volume:
  jwt_volume:
networks:
  internal:
  traefik_public:
    external: true
Traefik compose:
  traefik:
    container_name: traefik
    image: traefik:v3.1
      - target: 80
        published: 80
        protocol: tcp
        mode: host
      - target: 443
        published: 443
        protocol: tcp
        mode: host
    networks:
      - public
    extra_hosts: ["host.docker.internal:host-gateway"]
      - /home/admin/containers/traefik/config:/etc/traefik:Z
      - /home/admin/containers/traefik/cloudflare:/certificates:ro
    labels:
      # Dashboard/API
      traefik.http.routers.traefik-api.rule: Host(`traefik.domain.com`) && (PathPrefix(`/api`) || PathPrefix(`/dashboard`))
      traefik.http.routers.traefik-api.entrypoints: https
      traefik.http.routers.traefik-api.tls: true
      traefik.http.routers.traefik-api.service: api@internal
      traefik.http.routers.traefik-api.middlewares: admin-auth@file
      # Metrics
      traefik.http.routers.traefik-metrics.rule: Host(`traefik.domain.com`) && PathPrefix(`/metrics`)
      traefik.http.routers.traefik-metrics.entrypoints: https
      traefik.http.routers.traefik-metrics.tls: true
      traefik.http.routers.traefik-metrics.service: prometheus@internal
      traefik.http.routers.traefik-metrics.middlewares: admin-auth@file
networks:
  public:
    driver: bridge
    ipam:
      driver: default
      config:
      - subnet: 172.18.0.0/16
        gateway: 172.18.0.1
Traefik.yml
# Log level INFO|DEBUG|ERROR
log:
  level: INFO
api:
  dashboard: true
accessLog: {}
metrics:
  prometheus:
    buckets:
      - 0.100000
      - 0.300000
      - 1.200000
      - 5.000000
    addEntryPointsLabels: true
    addServicesLabels: true
entryPoints:
  http:
    address: ":80"
    http:
      redirections:
        entryPoint:
          to: https
          scheme: https
          permanent: true
  https:
    address: :443
    # This is here to ensure that LetsEncrypt is applied to all routers
    http:
      tls:
        certResolver: lts
providers:
  docker:
    defaultRule: Host(`{{ index .Labels "com.docker.compose.service" }}.domain.com`)
    exposedByDefault: false
    network: traefik_public
  file:
    filename: /etc/traefik/dynamic.yml
experimental:
  plugins:
    cloudflarewarp:
      modulename: github.com/BetterCorp/cloudflarewarp
      version: v1.3.0
Dynamic.yml
tls:
  stores:
    default:
      defaultCertificate:
        certFile: /certificates/domain.com.pem
        keyFile: /certificates/domain.com.key
http:
  middlewares:
    cloudflare:
      plugin:
        cloudflarewarp:
          disableDefault: false
          trustip: # Trust IPS not required if disableDefault is false - we will allocate Cloud Flare IPs automatically
            - "2400:cb00::/32"
    admin-auth:
      basicAuth:
        users:
          - "REDACTED"
          - "REDACTED"
    SslHeader:
      headers:
        FrameDeny: true
        AccessControlAllowMethods: 'GET,OPTIONS,PUT'
        AccessControlAllowOriginList:
          - origin-list-or-null
        AccessControlMaxAge: 100
        AddVaryHeader: true
        BrowserXssFilter: true
        ContentTypeNosniff: true
        ForceSTSHeader: true
        STSIncludeSubdomains: true
        STSPreload: true
        ContentSecurityPolicy: default-src 'self' 'unsafe-inline'
        CustomFrameOptionsValue: SAMEORIGIN
        ReferrerPolicy: same-origin
        PermissionsPolicy: vibrate 'self'
        STSSeconds: 315360000
Snippet of the logs showing Traefiks IP - 172.18.0.2 instead of the X-Forwarded-For IP:
172.18.0.2 - - [24/Feb/2025:07:36:57 +0000] "GET /auth/is-authenticated.json?api-version=v2 HTTP/1.1" 200 277 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
172.18.0.2 - - [24/Feb/2025:07:37:57 +0000] "GET /auth/is-authenticated.json?api-version=v2 HTTP/1.1" 200 277 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
172.18.0.2 - - [24/Feb/2025:07:38:57 +0000] "GET /auth/is-authenticated.json?api-version=v2 HTTP/1.1" 200 277 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
172.18.0.2 - - [24/Feb/2025:07:39:57 +0000] "GET /auth/is-authenticated.json?api-version=v2 HTTP/1.1" 200 277 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
172.18.0.2 - - [24/Feb/2025:07:40:57 +0000] "GET /auth/is-authenticated.json?api-version=v2 HTTP/1.1" 200 277 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
172.18.0.2 - - [24/Feb/2025:07:41:57 +0000] "GET /auth/is-authenticated.json?api-version=v2 HTTP/1.1" 401 282 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
2025-02-24 07:41:57,598 INFO reaped unknown pid 916 (exit status 0)
2025-02-24 07:41:57,599 INFO reaped unknown pid 918 (exit status 0)
172.18.0.2 - - [24/Feb/2025:07:43:07 +0000] "GET /auth/is-authenticated.json?api-version=v2 HTTP/1.1" 401 282 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
2025-02-24 07:43:07,153 INFO reaped unknown pid 957 (exit status 0)
2025-02-24 07:43:07,153 INFO reaped unknown pid 959 (exit status 0)
Healthcheck from the CLI:
 [INFO] Linux 016ea04399a2 5.14.0-427.13.1.el9_4.x86_64 #1 SMP PREEMPT_DYNAMIC Wed May 1 19:11:28 UTC 2024 x86_64 GNU/Linux
 [PASS] PHP version 8.2.26.
 [HELP] See `timedatectl | grep -i -A 1 clock`. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
 [PASS] Full base url is set to https://passbolt.domain.com
 SMTP settings
 [HELP] You can try:
 [PASS] Using latest passbolt version (4.11.1).
 [PASS] 34 tables found.
