I downloaded passbolt-repo-setup.ce.sh, but I found that the version of mariadb inside is 10.4, which is no longer available. Could you please update this script? This would make Passbolt even more perfect!
Hello @syx,
I am quite surprise that you were able to go through the script since centos7 is deprecated and it is not inside the supported distro list. When did you download the install script?
Install Passbolt on CentOS 7 | Passbolt documentation.
I downloaded it here. Thank you for your prompt reply. I will use the supported system version later.
