Hi everyone,
I have installed Passbolt CE using Docker Rootless.
Everything seems to be working regarding the SMTP configuration:
The test emails are sent successfully.
Notification emails (e.g., when a folder is shared) are also working fine.
However, users do not receive “invitation” emails. I don’t see any errors in the GUI, the logs, or the database. It seems like the invitation emails are stuck in the queue. But they are processed because I see the status changed.
Thanks for your help!
$ ./cake version
5.2.9
$ ./cake passbolt healthcheck
If you want to have more information about the different checks, please take a look at the documentation: https://www.passbolt.com/docs/admin/server-maintenance/passbolt-api-status/.
[INFO] Linux 13c0fb742908 6.8.0-101-generic #101-Ubuntu SMP PREEMPT_DYNAMIC Mon Feb 9 10:15:05 UTC 2026 x86_64 GNU/Linux
[PASS] PHP version 8.4.16.
[INFO] gpg (GnuPG) 2.4.7 / libgcrypt 1.11.0
[HELP] See `timedatectl | grep -i -A 1 clock`. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
[PASS] Full base url is set to http://192.168.2.20:8686
SMTP settings
[HELP] You can try:
[PASS] Using latest passbolt version (5.9.0).
[HELP] Check App.fullBaseUrl url scheme in /etc/passbolt/passbolt.php.
[PASS] 35 tables found.
[PASS] The database version is supported.
Metadata
Checklist**
