Problem caused by centos with plesk
Hi, I have an issue with the installation of passbolt on my server.
Server run CentOS Linux 7.6.1810, the problem is that on this server there is installed Plesk Obsidian 18.0.20, I can’t install passbolt on a vanilla server at this moment.
The problem is a conflict with nginx (Error: sw-nginx conflicts with 1:nginx-1.20.0-1.el7.ngx.x86_64) there is a working solution to run passbolt in my conditions?
Hi @Fadora Welcome to the forum!
You could try running the Docker version to avoid the nginx version conflicts.
Thanks for your reply @garrett, I never used Docker, can you explain me approximately how can I do? Or if you can link me documentation about this method…
@Fadora Sure: Install Docker Engine on CentOS | Docker Documentation
Docker engine gets installed first. Then follow Passbolt Help | Docker passbolt installation which will get you the passbolt container. Follow the instructions catefully and ultimately the docker-compose.yml file is used to launch the container(s).
