Question regarding passbolt pro subscription
Hi, I have a question with the feature within the Business version “Instances limit”, what does this refer to? to a single virtual or physical machine with passbolt installed?
Thank you
Hello @Witty,
We consider an instance a given installation of passbolt, e.g. a given database instance for a given domain (URL). For example you can have the same instance running on multiple machines in the case of high availability setup.
I hope that makes sense.
yes, I supposed it was exactly that, a passbolt installation including the mariadb.
The question is resolved.
Regards
