Wondering if redhat 7 is supported or if the CentOS script can be modified to deploy on Redhat…
Hi!
Redhat has not yet been tested, maybe some small modifications are required we will dig into it!
Thanks! Happy to help or test if I can
@tblade The code for the existing CentOS script is available there: https://github.com/passbolt/passbolt_install_scripts
