[X] I have read intro post:
Server: Ubuntu 18.04 LTS
Mail config:
// Email configuration. 'EmailTransport' => [ 'default' => [ 'className' => 'Smtp', 'host' => 'smtp.strato.de', 'port' => 465, 'username' => 'xxxxxxxxx', 'password' => 'xxxxxxxxx', // Is this a secure connection? true if yes, null if no. 'tls' => true, //'timeout' => 30, //'client' => null, //'url' => null, ], ],
Trace of send_test_mail:
Trace
A test email could not be sent.
Error: SMTP timeout.
Healtcheck:
root@password:/var/www/passbolt# sudo su -s /bin/bash -c “./bin/cake passbolt healthcheck” www-data
[PASS] PHP version 7.2.24-0ubuntu0.18.04.2.
[PASS] Full base url is set to xxxxx
fopen(xxxxx): failed to open stream: operation failed
[PASS] 23 tables found
[PASS] Using latest passbolt version (2.12.0).
Mails will not be sent, I’m using an external mail provider called Strato, which accepts SMTP via TLS on smtp.strato.de:465
