Some problem with docker+reverseproxy
Hi all, i have some issues…
If i try to login in anon tab:
server. x-gpgauth-authenticated should be set to false during the verify stage
And cant login
If i try lo login on another browser passbolt tell me to check my email, i receive a recovery account email and the page ask me for the recovery kit.
That’s normal?
I see this in the log when passbolt container starts:
wait-for.sh: waiting for db:3306 without a timeout
wait-for.sh: db:3306 is available after 4 seconds
gpg: key 8809715682DC6738: public key "Passbolt default user <passbolt@yourdomain.com>" imported
gpg:               imported: 1
gpg: key 8809715682DC6738: "Passbolt default user <passbolt@yourdomain.com>" not changed
gpg: key 8809715682DC6738: secret key imported
gpg:   secret keys imported: 1
healthcheck
[INFO] Linux dded31a902ae 6.6.87.2-microsoft-standard-WSL2 #1 SMP PREEMPT_DYNAMIC Thu Jun  5 18:30:46 UTC 2025 x86_64 GNU/Linux
[PASS] PHP version 8.4.16.
[INFO] gpg (GnuPG) 2.4.7 / libgcrypt 1.11.0
[FAIL] The temporary directory and its content are not writable, or are executable.
[HELP] you can try:
[HELP] sudo chown -R www-data:www-data /var/lib/passbolt/tmp/
[HELP] sudo chmod -R 775 $(find /var/lib/passbolt/tmp/ -type d)
[HELP] sudo chmod -R 664 $(find /var/lib/passbolt/tmp/ -type f)
[HELP] See timedatectl | grep -i -A 1 clock. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
[PASS] Full base url is set to https://pwbolt.huginn.ovh
SMTP settings
[HELP] You can try:
[FAIL] The server key fingerprint doesn’t match the one defined in /etc/passbolt/passbolt.php.
[HELP] sudo su -s /bin/bash -c “gpg --list-keys --fingerprint --home /var/lib/passbolt/.gnupg” www-data | grep -i -B 2 ‘SERVER_KEY_EMAIL’
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c “gpg --home /var/lib/passbolt/.gnupg --import /etc/passbolt/gpg/serverkey_private.asc” www-data
[PASS] Using latest passbolt version (5.8.0).
[PASS] 35 tables found.
Metadata
[FAIL] 10 error(s) found. Hang in there!
Compose:
db:
image: mariadb:10.11
restart: unless-stopped
MYSQL_RANDOM_ROOT_PASSWORD: “true”
MYSQL_DATABASE: “censored”
MYSQL_USER: “censored”
MYSQL_PASSWORD: “censored”
- “D:/Docker/PassBolt/database:/var/lib/mysql”
depends_on:
- db
APP_FULL_BASE_URL: https://censored.ovh
PASSBOLT_SECURITY_PROXIES_ACTIVE: “true”
PASSBOLT_SECURITY_PROXIES_HEADER: “X-Forwarded-For”
PASSBOLT_SECURITY_PROXIES_ALLOW_FROM: “172.17.0.1”
DATASOURCES_DEFAULT_HOST: “db”
DATASOURCES_DEFAULT_USERNAME: “censored”
DATASOURCES_DEFAULT_PASSWORD: “censored”
DATASOURCES_DEFAULT_DATABASE: “censored”
EMAIL_DEFAULT_FROM_NAME: “censored Passbolt”
EMAIL_DEFAULT_FROM: “noreply@censored.ovh”
EMAIL_TRANSPORT_DEFAULT_HOST: “censored”
EMAIL_TRANSPORT_DEFAULT_PORT: “587”
EMAIL_TRANSPORT_DEFAULT_USERNAME: “noreply@censored.ovh”
EMAIL_TRANSPORT_DEFAULT_PASSWORD: “censored”
EMAIL_TRANSPORT_DEFAULT_TLS: “true”
- “D:/Docker/PassBolt/gpg:/etc/passbolt/gpg”
- “D:/Docker/PassBolt/jwt:/etc/passbolt/jwt”
- “D:/Docker/PassBolt/tmp:/var/lib/passbolt/tmp”
command:
“/usr/bin/wait-for.sh”,
“-t”,
“0”,
“db:3306”,
“/docker-entrypoint.sh”,
- “8183:80”
- “8184:443”
Apache proxypass
<VirtualHost *:443>
ServerName censored.ovh
# ================= SSL =================
SSLEngine on
SSLCertificateFile "D:/Programmi/Apache24/conf/ssl/censored.ovh-chain.pem"
SSLCertificateKeyFile "D:/Programmi/Apache24/conf/ssl/censored.ovh-key.pem"
SSLProtocol             all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
SSLHonorCipherOrder     on
SSLCipherSuite          EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH
SSLCompression          off
SSLSessionTickets       off
Protocols h2 http/1.1
# ================= Proxy =================
ProxyRequests Off
ProxyPreserveHost On
SSLProxyEngine On
# Backend Passbolt è HTTPS locale → ok self-signed
SSLProxyVerify none
SSLProxyCheckPeerCN off
SSLProxyCheckPeerName off
ProxyTimeout 300
ProxyBadHeader Ignore
# ================= Headers (inform backend) =================
RequestHeader set X-Forwarded-Proto "https"
RequestHeader set X-Forwarded-Port "443"
RequestHeader set X-Forwarded-For "%{REMOTE_ADDR}s"
RequestHeader set X-Forwarded-Host "%{HTTP_HOST}s"
# ================= ProxyPass ROOT -> backend root =================
ProxyPass        "/"  "https://127.0.0.1:8184/"  connectiontimeout=5 timeout=300 keepalive=On
ProxyPassReverse "/"  "https://127.0.0.1:8184/"
# ================= WebSocket / Upgrade (root) =================
RewriteEngine On
RewriteCond %{HTTP:Upgrade} =websocket [NC]
RewriteRule /(.*)  wss://127.0.0.1:8184/$1  [P,L]
# ================= Sicurezza: limitazione IP SOLO su /app/ =================
<Location /app/>
    Require ip censored
    Require ip censored
    Require ip censored
</Location>
# ================= Header di sicurezza =================
Header always set Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
Header always set X-Frame-Options "SAMEORIGIN"
Header always set X-Content-Type-Options "nosniff"
Header always set Referrer-Policy "strict-origin-when-cross-origin"
Header always set Content-Security-Policy "default-src 'self'; script-src 'self' 'unsafe-inline' 'unsafe-eval'; connect-src 'self' wss:; img-src 'self' data:; style-src 'self' 'unsafe-inline';"
ServerSignature Off
Header unset ETag
# ================= Logs =================
ErrorLog "D:/Programmi/Apache24/logs/censored-error.log"
CustomLog "D:/Programmi/Apache24/logs/censored-access.log" combined
</VirtualHost>
Same problem here with browser extension
