i tried to upgrade my Ubuntu from 20.04 to 22.04, after this Passbolt didn’t work.
Is there any Checklist or to-do for Passbolt if i upgrade my Ubuntu Version?
I didn’t find any manual for this. Only for migration from on server to another server but not for a Server upgrade.
I use Passbolt Version 3.8.4 Pro.
Hey @Holla_Die_Waldfee just to be clear, were you doing an in place update of Ubuntu or did you bring up a 22.04 server along side your existing 20.04 and then migrate over?
Typically the recommended approach would be migrating to a new server, which this page covers.
As Ubuntu 20 is shipped with php7.4 and Ubuntu 22 with php8.1, can you also check if your /etc/nginx/sites-enabled/nginx-passbolt.confnginx configuration file contains any php-7.4 occurence ? If yes, you should try to edit the file and replace 7.4 with 8.1, then restart the nginx service with sudo systemctl restart nginx.
