currently a few websites require me to set a new password every 2 months or so. when i want to update a password it is unnecessary difficult.
Currently i have to generate a new password. go to my passbolt instance find the entry and set it to the new password. If i somehow got something wrong in my clipboard it locks me out or i forgot to copy the password. or the clipboard has timedout. or i have accidentally left the site and the old password is gone and i need to reset the password.
creating a new saved password does not work since i would have to reshare the with the organisation
Q2 - Who is impacted?
every user that wants to change a password on an existing site.
make it easier for users to update passwords.
Make a way to update the password, by generating a new password for an existing entry.
keep the old password for a limited amount of time.
after like 1 or 2 uses remove the old password.
