🚨 A quick update for Debian users
Hey everyone!
Debian 12: Bookworm :books::worm: was released in June and has a variety of new features and improved stability. If you’re using passbolt on Debian we encourage you to backup your instance then update to version 12, you can use the guide on the help site.
Learn more about Debian 12: https://www.debian.org/releases/bookworm/
It sounds really interesting. Do you know what SO is the Docker image based?
Maybe it is possible to upgrade the base to Debian 12
The passbolt docker image is based on Debian 12 (codename Bookworm): https://github.com/passbolt/passbolt_docker/blob/master/debian/Dockerfile#L1
Hello everyone! This is just a reminder to update to Debian 12.
You can get started by:
  1. Getting to know more about Debian 12: Release Notes for Debian 12 (bookworm), 64-bit PC
  2. Backing-up passbolt using the guide that fits your case: Passbolt Help | Backup
  3. Following the migration instructions to update: Passbolt Help | Migrate an existing Passbolt CE to a new Debian server
As always, contact us if you have any questions or feedback, or if you encounter any problems with the update!
