Action Required: Nginx critical vulnerabilities (NGINX2Root) for self-hosted instances
Today, security researchers disclosed five critical Nginx vulnerabilities collectively known as NGINX2Root. This includes CVE-2026-123007 and CVE-2026-123633, which allow for unauthenticated remote code execution (RCE).
Passbolt Cloud: Not affected. No action is needed.
Self-Hosted Passbolt: Immediate action is required to secure your server.
Please check our Incident Page for the latest status, affected versions, and immediate mitigation and patching instructions. We will continue to post updates there as new packages and Docker images become available.
Update — Debian, RPM, and Docker packages with HTTP2 disabled
Passbolt 5.18.0-2 Debian and RPM packages include a default Nginx configuration that sets http2 off;. Updated Docker images have also been released. These updates mitigate the two HTTP/2 vulnerabilities affecting self-hosted Passbolt installations using Nginx: CVE-2026-123007 and CVE-2026-123633.
If you use a customized Nginx configuration, verify that HTTP/2 is disabled after upgrading. We plan to restore the default HTTP/2 setting in a future release once patched Nginx packages are available across our supported operating systems.
Update - Passbolt Docker images with HTTP/2 disabled by default
Docker users can update their corresponding images to 5.18.0-2:
  • 5.18.0-2-latest-pro sha256:056dd0038345c2086fd40eb3214420274a3e37acdbe5f07e48371ccd2ea7a079
  • 5.18.0-2-latest-pro-openshift sha256:b28b22ad6892ab699ff4341458a7427155a234c02aeeeaf1555864aa9f0f1816
  • 5.18.0-2-latest-pro-non-root sha256:f75f88f4cb0f66948bc37151b5cc11857064ffd86eccc12ff2c5eaf0fb85d1f8
  • 5.18.0-2-latest-ce sha256:dfa660663887531c0a70e50a4f7e58cd60103f259dc293d537dccfbeb602a656
  • 5.18.0-2-latest-ce-openshift sha256:c05b8311e7a652d73a52720565ef30b2817ff8c37de2bc3565580028b7634007
  • 5.18.0-2-latest-ce-non-root sha256:4e018d494b0860f23d85bf3eed8a043c582c74b1b17c4f553391a04a7cf54eb8
Update - Manual HTTP/2 step required for existing Package, OVA, and AMI installations
Updating to Passbolt 5.18.0-2 disables HTTP/2 by default for Docker and fresh installations, while existing Linux package, OVA, and AMI installations preserve their active Nginx SSL configuration files during an upgrade.
If you run an existing package, OVA, or AMI instance, manually disable HTTP/2 until your OS distribution releases a patched Nginx package:
  1. Find active http2 directives: sudo grep -rn http2 /etc/nginx /etc/passbolt
  2. Remove http2 from every matching listen line (e.g., change listen 443 ssl http2; to listen 443 ssl;).
  3. Test and reload Nginx: sudo nginx -t && sudo systemctl reload nginx
  4. Verify HTTP/2 is disabled (the output should begin with HTTP/1.1): curl -skI --http2 https://localhost | head -1
Resolved — Nginx security updates available
Updated Passbolt Docker images containing Nginx and PHP security fixes are available. The major supported operating systems have also released patched Nginx packages.
Please update to the latest Passbolt image or package and apply your operating system’s security updates. If you previously disabled HTTP/2 as a mitigation, keep it disabled for now. We plan to release a Passbolt update next week that re-enables HTTP/2 by default.
