Hello everyone!
I need help because my passbolt is down and I don´t know why. Here is the output of healthcheck command line:
____ __ ____ / __ \____ _____ ____/ /_ ____ / / /_/ // / __ `/ / / __ / __ / / _/
// _,///./_//__/Open source password manager for teams
[PASS] PHP version 7.2.24-0ubuntu0.18.04.13.
[PASS] Mbstring extension is installed.Config files
[PASS] The passbolt config file is presentCore config
[PASS] Full base url is set to https://psb.wzbdev.com
[HELP] Check the network settingsSSL Certificate
[HELP] fopen(): https:// wrapper is disabled in the server configuration by allow_url_fopen=0
fopen(https://psb.wzbdev.com/healthcheck/status.json): failed to open stream: no suitable wrapper could be foundDatabase
[PASS] 24 tables found
[PASS] The database schema up to date.GPG Configuration
[FAIL] The public key cannot be used to encrypt a message
[HELP] Make sure that the server private key is valid and that there is no passphrase.
[HELP] Make sure you imported the private server key in the keyring of the webserver user.
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c “gpg --home /home/www-data/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.asc” www-data
[FAIL] The private key cannot be used to sign a message
[HELP] you can try:
[FAIL] The public and private keys cannot be used to encrypt and sign a message
[FAIL] The public key cannot be used to verify a signature.Application configuration
[FAIL] Could not connect to passbolt repository to check versions. It is not possible check if your version is up to date.
[PASS] All email notifications will be sent.10 error(s) found. Hang in there!
The output of error.log
2022-09-12 15:21:33 Error: [Cake\Http\Exception\ForbiddenException] You need to login to access this location. (/var/www/passbolt/src/Auth/GpgAuthenticate.php:85)
Request URL: /resources.json?api-version=v2
I have tried running some commands like sudo su -s /bin/bash -c “gpg --home /home/www-data/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.asc” www-data but I don´t know how to get the password of www-data user.
Thanks!
