Android something went wrong
Hey guys.
I’m currently using passbolt version 4.2.0.
I just performed the upgrade, I came from version 3.6.
I connected my app from android but it is no longer working.
The app stopped working when we upgraded to version 3.6.
We tested it on several android phones, they all show the same error!
What can I do to try to find the problem?
Hi @OuverneY
What version of php are you using?
Passbolt v4 needs php 7.4 or higher.
Could you please post your Passbolt Health-Check so we can further investigate your issue.
Cheers
