Android Vivaldi Autofill does not work
I have managed to get the Passbolt overlay to be displayed on login forms. I click on it and log in to Passbolt.
  1. the entry is not found automatically based on the URL
  2. I search for it manually and select the entry, I end up on the website again, but cannot fill the form with Passbolt.
Everything works perfectly with Chrome. Now I don’t know whether this is a Vivaldi or Passbolt problem. In any case, it would be great if it worked just as well with vivaldi as it does with Chrome.
greetings , Frank
Hi Frank,
Sorry for the delayed response, but I’m coming here to happily inform you that in an Android release 2.1.1 of Passbolt, this particular issue was resolved
Thank you very much, that’s good to hear. In the meantime, I’ve switched to Brave. Like Vivaldi, it offers a little more data protection than Chrome and works perfectly with Passbolt.
