Alright, I’m looking into setting this up but I don’t see an Apache Proxy config file anywhere. I am not an Apache Guru, is there a simple example out there somewhere i’m not seeing?
I’ve found one for mattermost no problem, would this work?
<VirtualHost *:80>
If you’re not using a subdomain you may need to set a ServerAlias to:
ServerAlias www. mydomain .com
ServerName mysubdomain .mydomain .com
ServerAdmin hostmaster@ mydomain .com
ProxyPreserveHost On
Set web sockets
RewriteEngine On
RewriteCond %{REQUEST_URI} /api/v[0-9]+/(users/)?websocket [NC,OR]
RewriteCond %{HTTP:UPGRADE} ^WebSocket$ [NC,OR]
RewriteCond %{HTTP:CONNECTION} ^Upgrade$ [NC]
RewriteRule .* ws://127.0.0.1:8065%{REQUEST_URI} [P,QSA,L]
I added spaces so the forum would allow the posting.
