We were running Passbolt 2.7.1 via digital ocean image. Recently as you may know chrome update broke the web UI. We got around by downgrading the extension to an older version suggested on this forum.
Now, we’re trying to upgrade Passbolt digital ocean image v 2.7.1 to the latest Passbolt on docker.
Here are the steps I followed
- I took a database dump as suggested in the upgrade guide
- I copied files from /var/www/passbolt/config/gpg
serverkey_private.asc
serverkey.asc
- I copied the server fingerprint from /var/www/passbolt/config/passbolt.php
- I have the email attached to the key, which I got from
gpg serverkey_private.asc
command
I followed the upgrade guide for docker and came up with the below compose file
version: '3.9'
db:
image: mariadb:10.10
restart: unless-stopped
MYSQL_DATABASE: "passbolt"
MYSQL_USER: "passbolt"
MYSQL_PASSWORD: "P4ssb0lt"
- ./db.sql:/docker-entrypoint-initdb.d/dump.sql
image: passbolt/passbolt:latest
depends_on:
- db
APP_FULL_BASE_URL: [redact]
PASSBOLT_GPG_SERVER_KEY_FINGERPRINT: "[redact]"
PASSBOLT_KEY_EMAIL: "[redact]"
EMAIL_TRANSPORT_DEFAULT_CLASS_NAME: "Smtp"
EMAIL_DEFAULT_FROM: "[redact]"
EMAIL_TRANSPORT_DEFAULT_HOST: "[redact]"
EMAIL_TRANSPORT_DEFAULT_PORT: "587"
EMAIL_TRANSPORT_DEFAULT_USERNAME: "[redact]"
EMAIL_TRANSPORT_DEFAULT_PASSWORD: "[redact]"
- ./gpg:/etc/passbolt/gpg
- ./certs/certificate.key:/etc/ssl/certs/certificate.key:ro
- ./certs/certificate.crt:/etc/ssl/certs/certificate.crt:ro
command:
"/usr/bin/wait-for.sh",
"-t",
"0",
"db:3306",
"/docker-entrypoint.sh"
- 80:80
- 443:443
database_volume:
jwt_volume:
But after running the above compose file, the old user can not still open the web ui but a new user (created after the upgrade) can do everything without any problems.
Please advise what we may be doing wrong? How can this be fixed?
This is what old user sees
