As a user, I would like to be able the autofill more than only user and password
On some website, we have more than 2 fields to complete to connect (for example domain, username, password). With keepass, I can configure the action to autofill automatically the 3 fields, but with passbolt I can’t
Q2 - Who is impacted?
At the moment, I keep the third data in the Notes, so I have to first open passbolt (habitually I don’t open it, only run autofill and enter my password) then find the entry, show the note, then copy past.
It’s important but not urgent.
It’s a must have to easily manage transition from keepass (I feel like I lost some functionnality)
To personalize more fields to autocomplete custom fields. for example on a website asking for domain + user + password:
on the uri “login.mywebsite.com” username and password already know where they are. But we could add on the id/div “domain” the custom field “domain”.
Q5. Community support
