Binary breaks kdbx export
I noticed, that I can break the kdbx export with binary in notes or password entry.
Keepass says
Error while reading the database: XML error:
Unexpected ''.
Line 7, column 12
For example if I want to export a password with the following in the notes or password field: (Please not the hidden binary at the end, use the copy button from the preformatted text to copy it)
KvÌûçIE.Qçî
keepassxc cannot import it.
If I export to csv, this is the notes field in VIM:
KvÌûçIE.Qçî^U
The import from csv into keepassxc works and looks as expected:
KvÌûçIE.Qçî
Is this anything that could be fixed in passbolt export or a issue for keepassxc?
Best regards
Hello @lasa ,
I have tried to reproduce your issue and I’m not able to get the same output as the exported secret remain the same for both csv or kdbx.
I would like to know which version of Keepass are you using? Windows, Linux ?
I am using keepassxc on Linux.
$ keepassxc --version
KeePassXC 2.7.6
Did you copy the ^U character into the password field?
For reference my passbolt export csv:
"Title","Username","URL","Password","Notes","Group"
"test","test","","KvÌûçIE.Qçî","KvÌûçIE.Qçî",""
Edit: Please not that there is a invisible character at the end of the password and notes field.
I see the same error in kdb and kdbx files in both keepass and keepassxc. Has there ever been a resolution? The error I get refers to a line number higher than the file contains, so it is hard to find the conflicting entry.
