Hello!
I have the same problem on a clean install. After login, I see a blank page, as in the screenshot. Did you solve the problem?
Hello!
Hi @pfzim
and welcome to Passbolt community forum
Can you tell us more about your current installation ?
Can you also run a healthcheck command on your instance ?
On Debian/Ubuntu:
sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck"
On CentOS / install from source:
sudo -H -u www-data bash -c "/var/www/passbolt/bin/cake passbolt healthcheck"
Thanks !
Hi @AnatomicJC !
I am trying to install Passbolt on a server in a closed environment with no internet access.
I downloaded the package: https://download.passbolt.com/ce/debian/pool/stable/p/passbolt-ce-server/passbolt-ce-server_3.2.1-3~1627390708.gbp663784_all.deb.
The installation was successful, the database and the primary user were created.
After a successful login, I see a blank page.
# uname -a
Linux srv-web01 4.19.0-17-amd64 #1 SMP Debian 4.19.194-3 (2021-07-18) x86_64 GNU/Linux
# sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck"
[PASS] PHP version 7.3.29-1~deb10u1.
[PASS] Full base url is set to https://pass.gk.ro****.local
[PASS] 25 tables found
[FAIL] Could not connect to passbolt repository to check versions It is not possible check if your version is up to date.
Ok, there is nothing special in your healthcheck output. When you got your blank page, do you see any error in the /var/log/nginx error log files ?
If you enable the debug mode of your browser by pressing the F12 key, do you see any error in the network tab ?
You can also enable the passbolt extension debug mode. This is different from the previous console.
If you are using Google Chrome can you please go to: chrome://extensions
On Firefox, you can go to: about:debugging#/runtime/this-firefox
Thanks !
There are no errors in the logs of Nginx, on the Network and Console tab.
Errors are present only in the Google Chrome extension:
pass.gk.r.local/auth/is-authenticated.json:1 Failed to load resource: the server responded with a status of 404 (Not Found)
index.html:1 Unchecked runtime.lastError while running tabs.executeScript: The tab was closed.
at chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:36566:19
at ScriptExecution.executeScript (chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:36619:5)
at ScriptExecution.setGlobals (chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:36658:8)
at PageMod.__onTabUpdated (chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:36399:21)
at PageMod.__onAttachExistingTab (chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:36330:14)
at tabs.forEach (chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:36222:16)
at ScriptExecution.injectScripts (chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:36600:5)
at PageMod.__onTabUpdated (chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:36408:21)
at Object.chrome.tabs.query [as callback] (chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:36221:14)
6Unchecked runtime.lastError while running tabs.executeScript: No tab with id: 2.
at Object.callback (<URL>)
5pass.gk.r.local/auth/is-authenticated.json:1 Failed to load resource: the server responded with a status of 401 ()
999index.min.js:13015 Uncaught (in promise) TypeError: Cannot read property 'emit' of undefined
at Port.<anonymous> (index.min.js:13015)
at index.min.js:36464
at EventImpl.dispatchToListener (extensions::event_bindings:403)
at Event.publicClassPrototype.(anonymous function) [as dispatchToListener] (extensions::utils:138:26)
at EventImpl.dispatch_ (extensions::event_bindings:387)
at EventImpl.dispatch (extensions::event_bindings:409)
at Event.publicClassPrototype.(anonymous function) [as dispatch] (extensions::utils:138:26)
at dispatchOnMessage (extensions::messaging:392)
index.min.js:35362 Can not attach application if user is not logged in.
onAttach @ index.min.js:35362
580index.min.js:13015 Uncaught (in promise) TypeError: Cannot read property 'emit' of undefined
(anonymous) @ index.min.js:13015
(anonymous) @ index.min.js:36464
EventImpl.dispatchToListener @ extensions::event_bindings:403
publicClassPrototype.(anonymous function) @ extensions::utils:138
EventImpl.dispatch_ @ extensions::event_bindings:387
EventImpl.dispatch @ extensions::event_bindings:409
dispatchOnMessage @ extensions::messaging:392
index.min.js:11889 InvalidMasterPasswordError: This is not a valid passphrase
at Keyring.checkPassphrase (chrome-extension://jambapmihiogllcddplfkaamhgdgleha/index.min.js:32056:15)
(anonymous) @ index.min.js:11889
async function (async)
(anonymous) @ index.min.js:11886
214index.min.js:13015 Uncaught (in promise) TypeError: Cannot read property 'emit' of undefined
index.min.js:39861 GET https://pass.gk.r.local/auth/is-authenticated.json 401
_isAuthenticated @ index.min.js:39861
AuthService.isAuthenticated @ index.min.js:39835
checkAuthStatus @ index.min.js:30443
isAuthenticated @ index.min.js:30396
onAttach @ index.min.js:35361
_listeners.chrome.runtime.onConnect @ index.min.js:36267
dispatchOnConnectImpl @ extensions::messaging:363
dispatchOnConnect @ extensions::messaging:275
checkAuthStatusTimeout.setTimeout @ index.min.js:30473
setTimeout (async)
startCheckAuthStatusLoop @ index.min.js:30472
startCheckAuthStatusLoop @ index.min.js:30466
postLogin @ index.min.js:14695
login @ index.min.js:14687
login @ index.min.js:14678
(anonymous) @ index.min.js:11909
(anonymous) @ index.min.js:11907
there is so many 401 errors in your extension logs, who mean you are not authenticated to the application:
Can you try to clean browser cache and cookies, or try with a new fresh browser profile ? Did you try also with another browser ?
As you are running in a closed environment, maybe there is a kind of proxy between you and the server ?
Ok, Iâll try to clear cache and cookies.
The connection is direct, there is no proxy between the server and the client.
Can I work without this extension?
Hi, the web extension is mandatory as it contains your private GPG key and is used to encrypt / decrypt passwords, as explained here: Passbolt Help | How does it work?
Clearing cache and cookies did not resolve the issue.
Maybe the problem is that I installed the extension incorrectly?
Because I do not have direct access to the Internet, I had to download the extension from another computer in .crx format, unpack it and install it via development mode.
Is your server has the correct date and time ? There may be issues with GPG authentication if they are not synced.
The time is synchronized with the domain controller, correct on both the client and the server.
Can you purge again cache and cookies, then enable again the web extension debug console.
Then go to the Network tab and reproduce the login process:
You should have some traces. Can you click on the âArrow downâ symbol and send here the .har file ? It is a text file, it doesnât contains any sensitive data, but you can check before send it here.
I have uploaded the .har log: https://www.sendspace.com/file/8yp37q
Thanks for the har file, it was very helpful. I saw you are using Chrome/72.0.3626.121, released 2 years and 6 months ago. This version is too old. You should update at last version to use Passbolt extension and get last security fixes.
I noticed also you are requesting a https address with a :80 port:
Port 80 is not for https. Can you check on your server in /etc/passbolt/passbolt.php for âfullBaseUrlâ and check if the value starts with https ?
Hello!
Thanks for the help!
fullBaseUrl starts with https = https://pass.gâŚlocal
I cannot update Chrome, because I do not have administrative rights on the client machine.
But I have installed Microsoft Edge and itâs newer than Chrome.
The Passbolt extension works with it.
Great, Iâm glad to see you finally manage to connect to Passbolt. Chrome 72 is definitively too old.
