[PASS] PHP version 8.2.7.
[PASS] Full base url is set to http://pb.solarisq.com
[HELP] cURL Error (7) Failed to connect to pb.solarisq.com port 80 after 5999 ms: Couldn’t connect to server
[PASS] 31 tables found
[PASS] Using latest passbolt version (4.5.2).
[HELP] Check App.fullBaseUrl url scheme in /etc/passbolt/passbolt.php.
SMTP Settings
Hi everybody,
I installed some PASSBOLT but this is the first time I have this issue. I can use my PB instance and add some passwords if I need, but I have some blank pages when I want to go to admin menu I still have this white page, I can return to any other menu without issue, only admin is white.
The PB is only on local (no internet access).
Thanks in advance.
Regards,
