Hi guys.
We decide update the version image that we use, but we get the same result
root@orquestador-passman:/home/assertiva# helm search repo passbolt
NAME CHART VERSION APP VERSION DESCRIPTION
passbolt/passbolt 0.7.1 4.4.2-1-ce Helm chart for passbolt PRO and CE
root@orquestador-passman:/home/assertiva# kubectl get pods
NAME READY STATUS RESTARTS AGE
passbolt-cron-proc-email-28422448-d6q29 1/2 Terminating 2 63s
passbolt-cron-proc-email-28422449-k858z 0/2 ContainerCreating 0 3s
passbolt-depl-srv-65c854d995-8k85z 1/2 CrashLoopBackOff 7 (3m34s ago) 16m
passbolt-depl-srv-65c854d995-b7tfd 1/2 CrashLoopBackOff 7 (3m50s ago) 16m
passbolt-job-create-gpg-keys-6tp8b 0/1 Completed 0 17m
passbolt-job-create-jwt-keys-c4hvc 0/1 Completed 0 16m
passbolt-mariadb-primary-0 1/1 Running 0 16m
passbolt-mariadb-secondary-0 1/1 Running 0 16m
passbolt-redis-node-0 2/2 Running 0 16m
passbolt-redis-node-1 2/2 Running 0 15m
passbolt-redis-node-2 2/2 Running 0 15m
root@orquestador-passman:/home/assertiva# kubectl describe pod passbolt-depl-srv-65c854d995-8k85z
Namespace: default
Priority: 0
Service Account: passbolt-sa-common
Node: minikube/192.168.49.2
Start Time: Mon, 15 Jan 2024 19:12:29 +0000
Labels: app.kubernetes.io/instance=passbolt
app.kubernetes.io/name=passbolt
pod-template-hash=65c854d995
Annotations: checksum/cm-env: abdb4387db2d542e321552abe0ea9d8ef412e131ab334a3de9cd982963ca6032
checksum/sec-env: e1e2ff9f028cdda424fd2df2fdacef99bfc4ad4c734a56df85e52459af48b5e3
checksum/sec-gpg: eae9225d9004627194cb4734bfea9bdd1aa388152595235987b3c291e17bc4e8
checksum/sec-jwt: 669578721774534823e8319aa99fa088eeb757ee13c3a39320a6830b5515f896
checksum/sec-redis-proxy: d989c9965b3fdcacebd5841950530d23385bb0cac77d2b61f7aea24f6b457efb
Status: Running
IP: 10.244.36.244
IPs:
IP: 10.244.36.244
Controlled By: ReplicaSet/passbolt-depl-srv-65c854d995
Init Containers:
passbolt-depl-srv-init:
Container ID: docker://600fed84c05a16d9f04bc400d187662c217bfc11df2dea470bded4a330da9e9a
Image: mariadb
Image ID: docker-pullable://mariadb@sha256:4d5a0e687d469b1a1e08ea8829f46ef1d966d9e0a3a8f3613fcf61e933161c27
Port: <none>
Host Port: <none>
Command:
/bin/bash
Args:
-c
set -e
client="mariadb"
cat <<-EOF > /tmp/defaultsfile.cnf
[client]
user=${DATASOURCES_DEFAULT_USERNAME}
password=${DATASOURCES_DEFAULT_PASSWORD}
host=${DATASOURCES_DEFAULT_HOST}
connect-timeout=2
EOF
userhost="%"
client="mariadb"
while ! ${client} --defaults-file=/tmp/defaultsfile.cnf -e "SELECT 1" > /dev/null 2>&1; do
echo "Waiting for database connection..."
sleep 2
done
State: Terminated
Reason: Completed
Exit Code: 0
Started: Mon, 15 Jan 2024 19:12:48 +0000
Finished: Mon, 15 Jan 2024 19:13:33 +0000
Ready: True
Restart Count: 0
Environment Variables from:
passbolt-cm-env ConfigMap Optional: false
passbolt-sec-env Secret Optional: false
Environment:
DATASOURCES_DEFAULT_HOST: passbolt-mariadb-primary
Mounts:
/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-zrbcd (ro)
Containers:
passbolt-depl-srv:
Container ID: docker://32fa3599f36d4be83627c88f7431f1e33b82874f91061cc86adf55f21fbb63ee
Image: passbolt/passbolt:4.4.2-1-ce
Image ID: docker-pullable://passbolt/passbolt@sha256:d4a957640f93c936bf585c4efe3d5a77b679dece60b996f0c56d9ad09b064ca1
Ports: 443/TCP, 80/TCP
Host Ports: 0/TCP, 0/TCP
Command:
/bin/bash
Args:
-c
set -e
> /etc/supervisor/conf.d/cron.conf
/docker-entrypoint.sh
State: Waiting
Reason: CrashLoopBackOff
Last State: Terminated
Reason: Error
Exit Code: 1
Started: Mon, 15 Jan 2024 19:25:26 +0000
Finished: Mon, 15 Jan 2024 19:25:29 +0000
Ready: False
Restart Count: 7
Liveness: http-get https://:https/healthcheck/status.json delay=20s timeout=1s period=10s #success=1 #failure=3
Readiness: http-get https://:https/healthcheck/status.json delay=5s timeout=1s period=10s #success=1 #failure=3
Environment:
Mounts:
/etc/passbolt/app.php from passbolt-cm-app-php (ro,path="app.php")
/etc/passbolt/gpg from passbolt-sec-gpg (ro)
/etc/passbolt/jwt from passbolt-sec-jwt (ro)
/etc/ssl/certs/passbolt from passbolt-depl-srv-sec-tls (ro)
passbolt-depl-srv-redisproxy:
Container ID: docker://fb0a2fe3fc50df05f995c706a71ac0a79a4c4a010cc8d7f927ffc96e9167166b
Image: haproxy:latest
Image ID: docker-pullable://haproxy@sha256:13b79eadf1244de34b7de32cf4a8a68075381c745e35087397e6d2357c9dae6c
Port: <none>
Host Port: <none>
State: Running
Started: Mon, 15 Jan 2024 19:13:35 +0000
Ready: True
Restart Count: 0
Environment: <none>
Mounts:
/usr/local/etc/haproxy/haproxy.cfg from passbolt-depl-srv-sec-redis-proxy (ro,path="haproxy.cfg")
Conditions:
Type Status
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
passbolt-depl-srv-sec-tls:
Type: Secret (a volume populated by a Secret)
SecretName: passbolt-sec-tls
Optional: false
passbolt-sec-gpg:
SecretName: passbolt-sec-gpg
Optional: false
passbolt-cm-app-php:
Type: ConfigMap (a volume populated by a ConfigMap)
Optional: false
passbolt-sec-jwt:
SecretName: passbolt-sec-jwt
Optional: false
passbolt-depl-srv-sec-redis-proxy:
SecretName: passbolt-sec-redis-proxy
Optional: false
kube-api-access-zrbcd:
Type: Projected (a volume that contains injected data from multiple sources)
TokenExpirationSeconds: 3607
ConfigMapName: kube-root-ca.crt
ConfigMapOptional: <nil>
DownwardAPI: true
QoS Class: BestEffort
Node-Selectors: <none>
Tolerations: node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
Type Reason Age From Message
Normal Scheduled 16m default-scheduler Successfully assigned default/passbolt-depl-srv-65c854d995-8k85z to minikube
Normal Pulling 16m kubelet Pulling image "mariadb"
Normal Pulled 16m kubelet Successfully pulled image "mariadb" in 5.643s (16.457s including waiting)
Normal Created 16m kubelet Created container passbolt-depl-srv-init
Normal Started 16m kubelet Started container passbolt-depl-srv-init
Normal Pulling 15m kubelet Pulling image "haproxy:latest"
Normal Pulled 15m kubelet Successfully pulled image "haproxy:latest" in 1.487s (1.487s including waiting)
Normal Created 15m kubelet Created container passbolt-depl-srv-redisproxy
Normal Started 15m kubelet Started container passbolt-depl-srv-redisproxy
Normal Started 15m (x3 over 15m) kubelet Started container passbolt-depl-srv
Normal Created 15m (x3 over 15m) kubelet Created container passbolt-depl-srv
Warning Unhealthy 15m (x2 over 15m) kubelet Readiness probe failed: Get "https://10.244.36.244:443/healthcheck/status.json": dial tcp 10.244.36.244:443: connect: connection refused
Normal Pulled 14m (x4 over 15m) kubelet Container image "passbolt/passbolt:4.4.2-1-ce" already present on machine
Warning BackOff 103s (x66 over 15m) kubelet Back-off restarting failed container passbolt-depl-srv in pod passbolt-depl-srv-65c854d995-8k85z_default(6ceca2b5-e36a-4ef2-92a6-6f373eaa2f0d)
The pod log has not details about the problem:
root@orquestador-passman:/home/assertiva# kubectl logs passbolt-depl-srv-65c854d995-8k85z
Defaulted container "passbolt-depl-srv" out of: passbolt-depl-srv, passbolt-depl-srv-redisproxy, passbolt-depl-srv-init (init)
gpg: key 8E776579DD73EBDE: public key "Passbolt default user <passbolt@yourdomain.com>" imported
gpg: imported: 1
gpg: key 8E776579DD73EBDE: "Passbolt default user <passbolt@yourdomain.com>" not changed
gpg: key 8E776579DD73EBDE: secret key imported
gpg: unchanged: 1
gpg: secret keys read: 1
gpg: secret keys imported: 1
Installing passbolt
<!DOCTYPE html>
<html class="passbolt no-js no-passboltplugin version" lang="en">
<head>
<meta charset="utf-8"/>
<title>Passbolt | An Internal Error Has Occurred.</title>
/ ____/ /_/ (__ )__ ) /_/ / /_/ / / /_
Copyright (c) Passbolt SA (https://www.passbolt.com)
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as
published by the Free Software Foundation, either version 3 of the
License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see http://www.gnu.org/licenses/.
<meta name="description" content="Open source password manager for teams">
<meta name="keywords" content="Passbolt, password manager, online password manager, open source password manager">
<meta name="robots" content="noindex, nofollow">
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="shortcut icon" type="image/x-icon" href="https://passbolt.local/favicon.ico" />
<link rel="icon" href="https://passbolt.local/favicon_32.png" sizes="32x32" />
<link rel="icon" href="https://passbolt.local/favicon_57.png" sizes="57x57" />
<link rel="icon" href="https://passbolt.local/favicon_76.png" sizes="76x76" />
<link rel="icon" href="https://passbolt.local/favicon_96.png" sizes="96x96" />
<link rel="icon" href="https://passbolt.local/favicon_128.png" sizes="128x128" />
<link rel="icon" href="https://passbolt.local/favicon_192.png" sizes="192x192" />
<link rel="icon" href="https://passbolt.local/favicon_228.png" sizes="228x228" />
<base href="https://passbolt.local/">
<link rel="stylesheet" href="https://passbolt.local/css/themes/default/api_main.min.css?v=4.4.2"/></head>
<body spellcheck="false">
<div id="container" class="error page error-500">
<!-- header navigation -->
<header>
<div class="header first ">
<nav>
<div class="top navigation primary">
<ul>
<li class="left"><a href="https://passbolt.local/"><span>home</span></a></li>
<li class="right"><a href="https://passbolt.local/auth/login"><span>login</span></a></li>
</ul>
</div>
</nav>
</div>
</header>
<div id="content">
<div class="grid">
<div class="row">
<h2>An Internal Error Has Occurred</h2>
<p class="error">
An Internal Error Has Occurred. </p>
</div>
</div>
</div>
</div>
<footer>
<div class="footer">
<ul class="footer-links">
<li><a href="https://www.passbolt.com/terms">Terms</a></li>
<li><a href="https://www.passbolt.com/privacy">Privacy</a></li>
<li><a href="https://www.passbolt.com/credits">Credits</a></li>
<li id="version">
<a href="https://www.passbolt.com/credits" class="tooltip-left" data-tooltip="4.4.2">
<i class="fa fa-heart-o"></i>
<span class="visuallyhidden">Versions</span>
</a>
</li>
</ul>
</div>
</footer>
</div>
</body>
</html>
Running migrations
<!DOCTYPE html>
<head>
<header>
<nav>
<ul>
</ul>
</div>
</nav>
</div>
</header>
<div id="content">
<div class="grid">
<div class="row">
<p class="error">
</div>
</div>
</div>
</div>
<footer>
<li id="version">
</a>
</li>
</ul>
</div>
</footer>
</div>
</body>
</html>
Clearing cake caches
<!DOCTYPE html>
<head>
<header>
<nav>
<ul>
</ul>
</div>
</nav>
</div>
</header>
<div id="content">
<div class="grid">
<div class="row">
<p class="error">
</div>
</div>
</div>
</div>
<footer>
<li id="version">
</a>
</li>
</ul>
</div>
</footer>
</div>
</body>
</html>
<!DOCTYPE html>
<head>
<header>
<nav>
<ul>
</ul>
</div>
</nav>
</div>
</header>
<div id="content">
<div class="grid">
<div class="row">
<p class="error">
</div>
</div>
</div>
</div>
<footer>
<li id="version">
</a>
</li>
</ul>
</div>
</footer>
</div>
</body>
</html>
what can we do?
Regards.
