Hi!
I have a problem while upgrading from 2.7.2 to the latest 2.8 version. Following the steps at the upgrade doc site, I am stuck at:
root@vault:/var/www/passbolt
# su -s /bin/bash -c "/var/www/passbolt/bin/cake passbolt migrate --backup" www-data
Saving backup file: /var/www/passbolt/tmp/cache/database/backup_1554187057.sql
Success: the database was saved on file!
Running migration scripts.
using migration paths
- /var/www/passbolt/config/Migrations
using seed paths
- /var/www/passbolt/config/Seeds
using environment default
using adapter mysql
using database prod_passbolt
All Done. Took 0.0106s
using seed paths
Writing dump file `/var/www/passbolt/config/Migrations/schema-dump-default.lock`...
Warning Error: file_put_contents(/var/www/passbolt/config/Migrations/schema-dump-default.lock): failed to open stream: Permission denied in [/var/www/passbolt/vendor/cakephp/migrations/src/Command/Dump.php, line 105]
2019-04-02 06:37:38 Warning: Warning (2): file_put_contents(/var/www/passbolt/config/Migrations/schema-dump-default.lock): failed to open stream: Permission denied in [/var/www/passbolt/vendor/cakephp/migrations/src/Command/Dump.php, line 105]
An error occurred while writing dump file `/var/www/passbolt/config/Migrations/schema-dump-default.lock`
Cleared default cache
Cleared _cake_core_ cache
Cleared _cake_model_ cache
Any ideas?
