Caught in a login loop
I just upgraded my passbolt, and now I’m stuck in a login loop. The login screen shows as it should, but as its trying to log me in the page flashes a firefox error saying that I need an addon, then takes me back to the login page. I clearly have the addon, or I wouldn’t even be able to try to log in, and it is also the latest version. Health checks all pass too.
[PASS] PHP version 7.0.30-0+deb9u1.
[PASS] Full base url is set
[PASS] 19 tables found
[PASS] Using latest passbolt version (2.1.0).
@mayday010 could you try to delete the cookies in your browser for that domain and retry? It’s possible you were still logged in the previous version and the cookie is not getting cleared by the v2.
That didn’t work. Its still looping.
It looks like an issue with sessions, if it’s not the cookie i’m not sure what it could be.
Can you provide more information, like:
  • Which browser are you using?
  • Do you have the same behavior with another browser / another user?
  • Can you explain in detail the “loop” process you are seeing, e.g. does it redirect you first to https://yourdomain.com/ and then again on the login page? Or does it stay on the login page without reloading.
  • Can you check the network tab in your browser console and check for the responses.
  • Do you have any error in your browser console?
  • Do you have anything in your error log on your server?
  • I’m using firefox.
    -I’m the only user
  • Yes, the looping process is exactly as you described. After entering the password, the cog wheel spins as if it were logging me in. Then it tries to load the root page, and redirects back to the login.
  • The network tab reflects the process as described, I see a 302 redirecting to the login page
  • Console doesn’t show any errors, but there is a warning of “Strict-Transport-Security: The connection to the site is untrustworthy, so the specified header was ignored.”
  • There’s nothing in the error log. But if it helps to trace it down, here is a copy of the access log entries.
192.168.10.10 - - [27/Jul/2018:08:29:45 -0500] “POST /auth/login.json?api-version=v1 HTTP/1.1” 200 3345 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0”
192.168.10.10 - - [27/Jul/2018:08:29:46 -0500] “POST /auth/login.json?api-version=v1 HTTP/1.1” 200 4670 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0”
192.168.10.10 - - [27/Jul/2018:08:29:46 -0500] “GET /account/settings.json?api-version=v2 HTTP/1.1” 404 424 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0”
192.168.10.10 - - [27/Jul/2018:08:29:46 -0500] “GET /auth/checkSession.json?api-version=v1 HTTP/1.1” 403 1171 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0”
192.168.10.10 - - [27/Jul/2018:08:29:46 -0500] “GET / HTTP/1.1” 302 1066 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0”
192.168.10.10 - - [27/Jul/2018:08:29:46 -0500] “GET /auth/login HTTP/1.1” 200 3074 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0”
192.168.10.10 - - [27/Jul/2018:08:29:47 -0500] “GET /settings.json?api-version=v2 HTTP/1.1” 200 1376 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0”
192.168.10.10 - - [27/Jul/2018:08:29:47 -0500] “POST /auth/verify.json?api-version=v1 HTTP/1.1” 200 2929 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0”
Then I’m pretty sure it’s an issue with the sessions. You can clear the session cache on the server side see if that solves it (by restarting apache ro nginx). Otherwise you can try with another session engine: Sessions - 3.10
The only place I see mention of an engine is in this example.
‘Session’ => [
‘defaults’ => ‘database’,
‘handler’ => [
‘engine’ => ‘ComboSession’,
‘model’ => ‘Session’,
‘cache’ => ‘apc’
// Make sure to add a apc cache config
‘Cache’ => [
‘apc’ => [‘engine’ => ‘Apc’]
What engine options are available? Will changing the engine mean I have to use a different model, and or cache option, if so what options do I have? And in this example the default is database. Do I need to change it to database, or are there other options?
I had a similar issue when I upgraded. My problem was that the permissions required for the different directories was incorrect.
I had to do a few things since I am using SELinux. I reset all permissions first.
# Restablish the SELInux context:
sudo restorecon -Rv /var/www/passbolt
sudo restorecon -Rv /var/lib/php/fpm
# Change the owner of the webroot:
sudo chown -R nginx:nginx /var/www/passbolt
sudo chown -R nginx:nginx /var/lib/php/fpm/
# Change basic permissiones:
sudo chmod -R g+w /var/www/passbolt
sudo chmod g+s /var/www/passbolt
# Establish SELinux permissions:
sudo chcon -Rt httpd_sys_content_t /var/www/passbolt
sudo chcon -Rt httpd_sys_rw_content_t /var/www/passbolt/logs
sudo chcon -Rt httpd_sys_rw_content_t /var/www/passbolt/tmp
sudo chcon -Rt httpd_sys_rw_content_t /var/www/passbolt/webroot/img/public/
sudo chcon -Rt httpd_sys_rw_content_t /var/lib/php/fpm
I’m using nginx and php-fpm - both running as nginx user. So, the /var/lib/php/fpm directory was owned by php-fpm instead of nginx (changed that and it fixed my looping issue after upgrade.)
Note: I was looking as why my avatar images weren’t uploading - and by answering this I noticed I hadn’t done the something which I’ve added to the notes above and is now working.
Patrick
Patrick, I appreciate the tips, but I’m not currently using selinux, nor nginx.
@mayday010. As you’re upgrading your passbolt there is a small chance that it comes from the Firefox third party cookies settings, but better to be sure. Can you check that your Firefox “accept[s] third-party cookies and site data”.
Cedric, thanks much, it was a cookie issue. As someone who takes basic steps (such as blocking cookies) to prevent things like internet tracking, why is this application written to require a third party cookie? Do you know which site(s) are need to write cookies? I’d like to add them to the exceptions instead of blindly allowing cookies.
Excellent! You can add an exception for the domain your passbolt instance is running on.
See : https://github.com/passbolt/passbolt_api/issues/177#issuecomment-333467502
