Cloudflare Proxy not working
Hi there!
I am having an question about CloudFlare Proxy,
When I enable this on an Linux installed version of PassBolt ill get the error code: ERR_TOO_MANY_REDIRECTS…
How can i fix this so its not exposing my ip?
Hey @julianb welcome to the forum!
Since you are using a cloudflare proxy here I am guessing you have SSL handled with that which means you’d likely want to change the force ssl setting in /etc/passbolt/passbolt.php to false.
This seems to be the same issue another user was facing and the solution was switching to false for them
Tried just, but didnt work still too many redirects
Could you please tell us if you managed to solve the problem? I’ve encountered a problem when I enable captcha verification, Passbolt stops working and an error occurs: Something went wrong!
The operation failed with the following error: Could not verify the server key. Server internal error. Check with your administrator.
Hello @Romchik911 , this looks like the issues is not related to the proxy redirections.
Could you create a dedicated post for this?
Thanks
