Docker-CE Passbolt-CE not sending registration emails but test works
Trying to get this setup, but I’m a complete noob with docker, and 76% of one with Linux. Finally got it spun up with docker-compose on a VM Ubuntu 18.04 LTS Server - freshly created.
The test email will work using my configuration, but nothing else seems to send one out. Neither user registration or user recovery.
sudo docker-compose exec passbolt bin/cake passbolt send_test_email --recipient=xxx@xxx.com
 Debug email shell
Email configuration
Host: smtp.gmail.com
Port: 587
Username: xxx
Password: *********
TLS: true
Sending email from: xxx
Sending email to: xxx
Trace
[220] smtp.gmail.com ESMTP 2-v6sm11303340iom.34 - gsmtp
> EHLO localhost
[250] smtp.gmail.com at your service, [136.63.231.178]
[250] SIZE 35882577
[250] 8BITMIME
[250] STARTTLS
[250] ENHANCEDSTATUSCODES
[250] PIPELINING
[250] CHUNKING
[250] SMTPUTF8
> STARTTLS
> EHLO localhost
[250] SIZE 35882577
[250] 8BITMIME
[250] AUTH LOGIN PLAIN XOAUTH2 PLAIN-CLIENTTOKEN OAUTHBEARER XOAUTH
[250] PIPELINING
[250] CHUNKING
[250] SMTPUTF8
> AUTH LOGIN
[334] VXNlcm5hbWU6
[334] UGFzc3dvcmQ6
[235] 2.7.0 Accepted
> MAIL FROM:<xxx>
[250] 2.1.0 OK 2-v6sm11303340iom.34 - gsmtp
> RCPT TO:<xxx>
[250] 2.1.5 OK 2-v6sm11303340iom.34 - gsmtp
> DATA
[354] Go ahead 2-v6sm11303340iom.34 - gsmtp
> From: xxx
To: xxx
Date: Wed, 23 May 2018 21:21:40 +0000
Message-ID: <4cdeb8ed3be84cfe8736807992e8c52a@e7ae73d9fee8>
Subject: Passbolt test email
MIME-Version: 1.0
Congratulations!
[250] 2.0.0 OK 1527110501 2-v6sm11303340iom.34 - gsmtp
> QUIT
Also, I dumbed down the standard docker-compose.yml since I’ve got DB covered already:
version: '3.4'
    image: passbolt/passbolt:2.0.7-debian
    tty: true
    env_file:
      - env/passbolt.env
      - gpg_volume:/var/www/passbolt/config/gpg
      - images_volume:/var/www/passbolt/webroot/img/public
      - ###:443
  images_volume:
  gpg_volume:
sudo docker-compose exec passbolt su -s /bin/bash -c “./bin/cake passbolt healthcheck” www-data
/ _
//./_//__/
[PASS] PHP version 7.2.5.
[PASS] Full base url is set to https://xxx.com:###
[HELP] fopen(): Peer certificate CN=www.passbolt.local' did not match expected CN=xxx.com
fopen(https://xxx.com:###/healthcheck/status.json): failed to open stream: operation failed
[PASS] 18 tables found
[PASS] Using latest passbolt version (2.0.7).
Hi @joshleonhart!
Thanks for your report! Could you check if you have any logs in /var/log/cron.log and also check if executing the email task manuall outputs any problem:
su -c "./bin/cake EmailQueue.sender" -s /bin/bash www-data
Well that’s odd. Lots of these:
SMTP server did not accept the password.
Email 13 was not sent
This didn’t return anything
sudo docker-compose exec passbolt su -c “./bin/cake EmailQueue.sender” -s /bin/bash www-data
So I tried from a shell in the container (I think…) and got the same result:
root@e7ae73d9fee8:/var/www/passbolt# su -c “./bin/cake EmailQueue.sender” -s /bin/bash www-data
Please check the env variables of the www-data user and ensure they are correct: su -c "env | grep EMAIL" -s /bin/bash www-data
EMAIL_TRANSPORT_DEFAULT_PASSWORD=ishouldsetupapppassword
EMAIL_DEFAULT_FROM=xxx@xxx.com
EMAIL_TRANSPORT_DEFAULT_USERNAME=xxx
EMAIL_TRANSPORT_DEFAULT_TLS=true
EMAIL_TRANSPORT_DEFAULT_HOST=smtp.gmail.com
EMAIL_TRANSPORT_DEFAULT_PORT=587
Seems in order there.
