After following the tutorials to install PassBolt in docker from the healthcheck it is full errors and warning for some reason.
Also when trying to access the GUI I get a blank page as a response.
Implementation design:
Docker is running in a virtual machine inside a Proxmox and behind a pfSense Firewall also virtualized in the same system.
I have no issues with the docker machine since I have a mail server running and with DKIM, DMARC, SPF and certificates working.
I had to change the ports as you will see in the composer file below.
version: "3.9"
db:
image: mariadb:10.11
restart: unless-stopped
MYSQL_ROOT_PASSWORD: ""
MYSQL_DATABASE: "passbolt"
MYSQL_USER: ""
MYSQL_PASSWORD: ""
depends_on:
- db
APP_FULL_BASE_URL: "https://passbolt.bgvs.online"
DATASOURCES_DEFAULT_USERNAME: ""
DATASOURCES_DEFAULT_PASSWORD: ""
EMAIL_DEFAULT_FROM: "passbolt@bgvs.online"
EMAIL_TRANSPORT_DEFAULT_HOST: "mail.bgvs.online"
EMAIL_TRANSPORT_DEFAULT_PORT: "465"
EMAIL_TRANSPORT_DEFAULT_USERNAME: "passbolt@bgvs.online"
EMAIL_TRANSPORT_DEFAULT_PASSWORD: ""
command:
"/usr/bin/wait-for.sh",
"-t",
"0",
"db:3306",
"/docker-entrypoint.sh",
- 8081:80
- 4443:443
# - 80:8080
# - 443:4433
database_volume:
gpg_volume:
jwt_volume:
Below is the healthcheck.
www-data@df5c21ab6213:/usr/share/php/passbolt$ ./bin/cake passbolt healthcheck
[PASS] PHP version 8.2.7.
[PASS] Full base url is set to https://passbolt.bgvs.online
[HELP] cURL Error (28) Connection timed out after 30000 milliseconds
[PASS] 32 tables found
[HELP] you can try:
[PASS] Using latest passbolt version (4.3.0).
SMTP Settings
[FAIL] 6 error(s) found. Hang in there!
Thanks in advance.
