Docker: PASSBOLT_SSL_FORCE: "true" causes infinite loop
I’m experiencing an issue when configuring my docker instance.
When I enable the option PASSBOLT_SSL_FORCE: “true” on the docker-compose-ce.yaml I get an infinite redirection error.
I have already tried this solution - it didn’t help.
I’m also configuring all of my app settings via env variables. So I think it’s safe to ignore the passbolt.php errors.
Logs:
Installing passbolt
The /etc/passbolt/jwt/ directory should not be writable.
Please run ./bin/cake passbolt healthcheck for more information and help.
Running migrations
 Running migration scripts.
using migration paths
 - /etc/passbolt/Migrations
using seed paths
using environment default
using adapter mysql
using database passbolt
ordering by creation time
All Done. Took 0.0353s
Clearing cake caches
Clearing _cake_model_
Cleared _cake_model_ cache
Clearing _cake_core_
Cleared _cake_core_ cache
Enjoy! ☮
/usr/lib/python3/dist-packages/supervisor/options.py:474: UserWarning: Supervisord is running as root and it is searching for its configuration file in default locations (including its current working directory); you probably want to specify a "-c" argument specifying an absolute path to a configuration file for improved security.
  self.warnings.warn(
2024-10-15 17:32:54,566 CRIT Supervisor is running as root.  Privileges were not dropped because no user is specified in the config file.  If you intend to run as root, you can set user=root in the config file to avoid this message.
2024-10-15 17:32:54,566 INFO Included extra file "/etc/supervisor/conf.d/cron.conf" during parsing
2024-10-15 17:32:54,566 INFO Included extra file "/etc/supervisor/conf.d/nginx.conf" during parsing
2024-10-15 17:32:54,566 INFO Included extra file "/etc/supervisor/conf.d/php.conf" during parsing
2024-10-15 17:32:54,576 INFO RPC interface 'supervisor' initialized
2024-10-15 17:32:54,576 CRIT Server 'unix_http_server' running without any HTTP authentication checking
2024-10-15 17:32:54,577 INFO supervisord started with pid 1
2024-10-15 17:32:55,587 INFO spawned: 'php-fpm' with pid 107
2024-10-15 17:32:55,596 INFO spawned: 'nginx' with pid 108
2024-10-15 17:32:55,602 INFO spawned: 'cron' with pid 109
[15-Oct-2024 17:32:55] NOTICE: fpm is running, pid 107
[15-Oct-2024 17:32:55] NOTICE: ready to handle connections
[15-Oct-2024 17:32:55] NOTICE: systemd monitor interval set to 10000ms
2024-10-15 17:32:56,862 INFO success: php-fpm entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2024-10-15 17:32:56,862 INFO success: nginx entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2024-10-15 17:32:56,863 INFO success: cron entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
172.18.0.4 - - [15/Oct/2024:17:34:05 +0000] "GET / HTTP/1.1" 301 162 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/113.0"
172.18.0.4 - - [15/Oct/2024:17:37:19 +0000] "GET /auth/is-authenticated.json?api-version=v2 HTTP/1.1" 301 162 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:131.0) Gecko/20100101 LibreWolf/131.0.2"
Healthcheck:
 Healthcheck shell.....
 [PASS] PHP version 8.2.20.
 [PASS] Full base url is set to https://passbolt.example.com
 SMTP settings
 [HELP] you can try:
 [PASS] 31 tables found.
 [FAIL] 8 error(s) found. Hang in there!
Hello @nixer, as you are using docker with environment variables, you should type “source /etc/environment” before executing healthcheck command. This will give you a cleaner output.
Also, we need more context to try to find the problem. Trying to follow the guide showed when creating a post, we need to know your system os and version, how is installed, if you are using proxy, your configuration (in your case docker-compose and environment variables)…
I am digging this up, because the SSL error is my last error in the health check.
I am using traefik (and it seems to be working).
Heathcheck
[PASS] Using latest passbolt version (5.3.1).
docker-compose
#image: passbolt/passbolt:4.8.0-1-ce
restart: unless-stopped
depends_on:
  - db
- traefik
  APP_FULL_BASE_URL: "https://pass.acme.com"
  PASSBOLT_EMAIL_VALIDATE_MX: "true"
  PASSBOLT_SECURITY_SMTP_SETTINGS_ENDPOINTS_DISABLED: "true"
  DATASOURCES_DEFAULT_USERNAME: "RandoCarissian"
  DATASOURCES_DEFAULT_PASSWORD: "obfuscated"
  DATASOURCES_DEFAULT_DATABASE: "RandoCarissianDB"
Uncomenting the PASSBOLT_SSL_FORCE will make passbolt do the infinite redirect thingy. What can I do to help?
Server is 5.3.1
Hello @SSintermann,To help you, we need information about your infrastructure, such as the operating system, the full healthcheck and configuration files (mask sensitive information), whether you use proxies like Cloudflare tunnels, and so on.
Without this information, we can’t help you, as we have many variables that are out of context.
Sure, if you need more, I am happy to dig up more ;-). No fancy stuff installed, just traefik and passbolt. Though the traefikl serves two other sites as well
Thanks for your help
Healthcheck
/ _
//./_//__/
If you want to have more information about the different checks, please take a look at the documentation: https://www.passbolt.com/docs/admin/server-maintenance/passbolt-api-status/
[INFO] Linux 85eb299d48f6 6.1.0-35-cloud-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.137-1 (2025-05-07) x86_64 GNU/Linux
[PASS] PHP version 8.2.28.
[HELP] See timedatectl | grep -i -A 1 clock. More information: https://www.passbolt.com/docs/hosting/configure/ntp/
[PASS] Full base url is set to https://passbolt.acme
SMTP settings
[PASS] The SMTP Settings plugin endpoints are disabled.
[PASS] 34 tables found.
Metadata
docker-compose.yml
cat docker-compose.yml
version: “3.9”
db:
image: mariadb:10.11
MYSQL_RANDOM_ROOT_PASSWORD: “true”
MYSQL_DATABASE: “passboltdb”
MYSQL_USER: “rando”
MYSQL_PASSWORD: “rando”
depends_on:
  - db
- traefik
  APP_FULL_BASE_URL: "https://obfuscated"
  DATASOURCES_DEFAULT_USERNAME: "rando"
  DATASOURCES_DEFAULT_PASSWORD: "rando"
  DATASOURCES_DEFAULT_DATABASE: "passboltdb"
EMAIL_DEFAULT_FROM_NAME: “obfuscated”
EMAIL_DEFAULT_FROM: “obfuscated”
EMAIL_TRANSPORT_DEFAULT_HOST: “smtp.obfuscated”
EMAIL_TRANSPORT_DEFAULT_USERNAME: “obfuscated”
EMAIL_TRANSPORT_DEFAULT_PASSWORD: “obfuscated”
EMAIL_TRANSPORT_DEFAULT_TLS: ‘true’
networks:
  - traefik
  - default
command:
    "/usr/bin/wait-for.sh",
    "-t",
    "0",
    "db:3306",
    "/docker-entrypoint.sh",
labels:
  traefik.enable: "true"
  traefik.http.routers.passbolt-http.rule: "Host(`obfuscated`)"
  traefik.http.routers.passbolt-https.rule: "Host(`obfuscated`)"
traefik.docker.network: “traefik”
- 80:80
- 443:443
- 8080:80
- 4443:443
database_volume:
gpg_volume:
jwt_volume:
networks:
traefik:
external: true
traefik.yaml
cat traefik.yaml
global:
sendAnonymousUsage: true
log:
level: INFO
format: common
providers:
docker:
endpoint: ‘unix:///var/run/docker.sock’
watch: true
exposedByDefault: true
swarmMode: false
file:
directory: /etc/traefik/conf/
watch: true
api:
dashboard: false
debug: false
insecure: false
entryPoints:
web:
address: ‘:80’
http:
redirections:
entryPoint:
to: websecure
scheme: https
permanent: true
websecure:
address: ‘:443’
certificatesResolvers:
letsencrypt:
acme:
email: obfuscated
storage: /shared/acme.json
caServer: ‘https://acme-v02.api.letsencrypt.org/directory
keyType: EC256
httpChallenge:
entryPoint: web
tlsChallenge: {}
headers.yaml
cat headers.yaml
http:
middlewares:
SslHeader:
headers:
FrameDeny: true
AccessControlAllowMethods: ‘GET,OPTIONS,PUT’
AccessControlAllowOriginList:
- origin-list-or-null
AccessControlMaxAge: 100
AddVaryHeader: true
BrowserXssFilter: true
ContentTypeNosniff: true
ForceSTSHeader: true
STSIncludeSubdomains: true
STSPreload: true
ContentSecurityPolicy: default-src ‘self’ ‘unsafe-inline’
CustomFrameOptionsValue: SAMEORIGIN
ReferrerPolicy: same-origin
PermissionsPolicy: vibrate ‘self’
STSSeconds: 315360000
tls.yaml
cat tls.yaml
tls:
options:
default:
minVersion: VersionTLS12
sniStrict: true
curvePreferences:
- CurveP521
- CurveP384
cipherSuites:
- TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
- TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
- TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
OS for docker host (hostnamectl):
Operating System: Debian GNU/Linux 12 (bookworm)
Kernel: Linux 6.1.0-35-cloud-amd64
I think I have the problem, but if anyone is reading this and I’m wrong, please correct me.
You’re using Traefik with Let’s Encrypt to manage your SSL certificates. This means Traefik will terminate your HTTPS connection and then forward it to your Passbolt instance over HTTP.
Therefore, if you enable the PASSBOLT_SSL_FORCE environment variable, you’ll get an error, as you haven’t configured the certificates in Passbolt, and Traefik doesn’t send HTTPS traffic to Passbolt, so it’s left waiting for something that never arrives.
This is normal behavior, as described in the official guide (you can see that there’s no mention of enabling this environment variable). Since the connection between Traefik and Passbolt is internal to the Docker network, it’s not necessary to maintain this last step in HTTPS: https://www.passbolt.com/docs/hosting/configure/https/ce/docker-auto/
If you want to maintain the entire connection from the client to the Passbolt server in HTTPS mode, you must configure Traefik as passthrough and Passbolt with SSL certificates (but Traefik won’t manage your certificate renewals, as it will transfer them directly to the instance). You’ll need to configure certificate renewal in another way or do it manually.
In short: It should work perfectly without enabling the environment variable. If this isn’t happening, we can move on to troubleshooting that issue.
Where did you put your certificate on the traefik ? Passbolt?
If you are putting your certificate on traefik then no need to set the force SSL at the passbolt level.
Here is a lab config:
traefik:
    image: traefik:v3.3
      - "80:80"
      - "443:443"
      - "8080:8080"
      - ./logs/traefik:/logs
      - /var/run/docker.sock:/var/run/docker.sock
      - ./traefik/traefik.yml:/etc/traefik/traefik.yml
      - ./traefik/dynamic.yml:/etc/traefik/dynamic.yml
      - ./traefik/certs:/etc/traefik/certs
traefik.yml
# traefik.yml
entryPoints:
  web:
    address: ":80"
    http:
      redirections:
        entryPoint:
          to: websecure
          scheme: https
          permanent: true
  websecure:
    address: ":443"
api:
  dashboard: true
  insecure: true
accessLog:
  filePath: "/etc/traefik/access.log"
providers:
  docker:
    exposedByDefault: false
  file:
    filename: /etc/traefik/dynamic.yml
tls:
  certificates:
    - certFile: "/etc/traefik/certs/passbolt.pem"
      keyFile: "/etc/traefik/certs/passbolt.pem"
log:
  level: INFO
  filePath: "/logs/traefik.log"
  format: json
Dynamic.yml
# dynamic.yml
http:
  routers:
      rule: "Host(`passbolt.local`)"
      entryPoints:
        - websecure
      service: "passbolt"
      tls: true
      middlewares:
        - securityHeaders
        - passboltHeaders
    passbolt-http:
      entryPoints:
        - web
      middlewares:
        - redirect-to-https
      service: "passbolt"
    www-redirect:
      rule: "Host(`www.passbolt.local`)"
      entryPoints:
        - "websecure"
      middlewares:
        - "www-stripper"
      service: "noop@internal"
      loadBalancer:
        servers:
          - url: "http://passbolt1:80"
          - url: "http://passbolt2:80"
          - url: "http://passbolt3:80"
  middlewares:
    redirect-to-https:
      redirectScheme:
        scheme: https
        permanent: true
    www-stripper:
      redirectRegex:
        regex: "^https?://www\\.(.+)"
        replacement: "https://${1}"
        permanent: true
    passboltHeaders:
      headers:
        customRequestHeaders:
          X-Forwarded-Proto: "https"
          X-Forwarded-Port: "443"
          Host: "passbolt.local"
    securityHeaders:
      headers:
        customResponseHeaders:
          Strict-Transport-Security: "max-age=31536000; includeSubDomains; preload"
          X-Content-Type-Options: "nosniff"
          X-Frame-Options: "DENY"
          X-XSS-Protection: "1; mode=block"
This is not production ready so to take with a pinch of salt and adapt to your need.
Hi @Termindiego25 ,
indeed traefik is working fine with SSL - so I ignore the error.
Maybe there is a way for passbolt to ‘know’ that some https proxy is sitting in front of it and the error is omitted.
For documentation purposes I am happy now.
Thank you
