we have an installation of Passbolt CE, and we try to use DUO MFA. After saving configuration we get the error:
An internal error ocured. The server response could not be parsed.
The request to connect to DUO is going straight to the firewall which blocks the commuication. We need this request to go through forwaring proxy. How can we implement this?
Depending on your installation, could you try to update /var/www/passbolt/config/passbolt.php if it is a from source installation otherwise that’d be /etc/passbolt/passbolt.php
Inside the passbolt array, you will need to implement security.proxies.trustedProxies:
To be clear, i need the traffic from passbolt to DUO , to be forwarded through a forwarding proxy and not go straight to internet. So we need to define an outgoing proxy for internet requests, similarly as setting the /etc/environment of the OS
