Enable Debug and location
trying to setup passbolt, enabled debug mode also but could not find any new files under logs folder. ony error.log and cli-error.log are there but does not seem to contain any debug info. where does one find the debug logs.?.
Attached healthcheck output
[PASS] PHP version 7.2.23-1+ubuntu16.04.1+deb.sury.org+1.
[FAIL] Debug mode is on.
[PASS] Full base url is set to http://passbolt.ixed.com:7080
[PASS] 26 tables found
[FAIL] The private key cannot be used to sign a message
[HELP] Make sure that the server private key is valid and that there is no passphrase.
[HELP] Make sure you imported the private server key in the keyring of the webserver user.
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c “gpg --home /var/www/.gnupg --import /var/www/passbolt/passbolt/config/gpg/serverkey_private.asc” www-data
[FAIL] The public and private keys cannot be used to encrypt and sign a message
[PASS] Using latest passbolt version (2.11.0).
7 error(s) found. Hang in there!
Create cli-debug.log with web server rights and see if that helps.
Thank you. there is a file already in $PASSBOLT_HOME/logs/cli-error.log and is owned by www-data but dont see much debug info in the file.
Hi ksriramk,
You have already noted there are only two files. The suggestion is to create the missing cli-debug.log file. If you don’t know how to do that, you could use “touch cli-debug.log” while you are in the logs folder.
thanks a ton. I touched an empty file and changed ownership and then restarted Aapache too. i could not see the file being used.
dir as under $PASSBOLT_HOME/logs
drwxr-xr-x 14 www-data www-data 4096 Oct 9 12:10
-rw-rw-r-- 1 www-data www-data 19680 Oct 11 11:55 cli-error.log
-rw-rw-r-- 1 www-data www-data 0 Oct 14 16:07 cli-debug.log
drwxr-xrwx 2 www-data www-data 4096 Oct 14 16:11 .
-rw-r–r-- 1 www-data www-data 10205 Oct 14 17:02 error.log
any insights would be helpful
