Error upgrading from 5.11 to 5.12
Hi guys, i recently tried to upgrade my passsbolt CE from 5.11 (running stable) to 5.12 followed the commands as usual https://www.passbolt.com/changelog/api-bext/natural-blues-browser-extension-api
My server: Server information:
  • Debian GNU/Linux 11 (bullseye)
  • PHP 8.2.29
  • Passbolt CE 5.11 before upgrade
however this time it did not complete and go som errors as shown below ,
sudo apt --only-upgrade install passbolt-ce-server
sudo apt upgrade
Get:1 http://security.debian.org/debian-security bullseye-security InRelease [27.2 kB]
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Get:4 http://security.debian.org/debian-security bullseye-security/main Sources [288 kB]
Get:5 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [454 kB]
Get:6 http://security.debian.org/debian-security bullseye-security/main Translation-en [304 kB]
Get:7 https://packages.sury.org/php bullseye InRelease [6,136 B]
Err:7 https://packages.sury.org/php bullseye InRelease
  The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key <deb@sury.org>
Get:8 https://download.passbolt.com/ce/debian buster InRelease [35.8 kB]
Get:9 https://download.passbolt.com/ce/debian buster/stable amd64 Packages [14.1 kB]
Fetched 1,130 kB in 1s (791 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
5 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.sury.org/php bullseye InRelease: The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key <deb@sury.org>
W: Failed to fetch https://packages.sury.org/php/dists/bullseye/InRelease  The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key <deb@sury.org>
W: Some index files failed to download. They have been ignored, or old ones used instead.
The following packages were automatically installed and are no longer required:
  libgraphite2-3 libharfbuzz0b libraqm0 linux-image-5.10.0-13-amd64
  linux-image-5.10.0-23-amd64 linux-image-5.10.0-25-amd64
  linux-image-5.10.0-26-amd64 linux-image-5.10.0-27-amd64
  linux-image-5.10.0-28-amd64 linux-image-5.10.0-29-amd64
  linux-image-5.10.0-30-amd64 linux-image-5.10.0-31-amd64
  linux-image-5.10.0-33-amd64 linux-image-5.10.0-34-amd64
  linux-image-5.10.0-36-amd64 php7.4-cli php7.4-curl php7.4-fpm php7.4-gd
  php7.4-intl php7.4-json php7.4-mbstring php7.4-mysql php7.4-opcache
  php7.4-xml
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  php-ldap php8.4-ldap
Suggested packages:
  python-certbot-nginx | python-certbot-apache
The following NEW packages will be installed:
The following packages will be upgraded:
  passbolt-ce-server
1 upgraded, 2 newly installed, 0 to remove and 4 not upgraded.
Need to get 14.3 MB of archives.
After this operation, 12.6 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 https://packages.sury.org/php bullseye/main amd64 php8.4-ldap amd64 8.4.14-1+0~20251108.36+debian11~1.gbpca7cb9
  404  Not Found [IP: 151.101.3.52 443]
Err:2 https://packages.sury.org/php bullseye/main amd64 php-ldap all 2:8.4+97+0~20251117.58+debian11~1.gbp8726a7
Get:3 https://download.passbolt.com/ce/debian buster/stable amd64 passbolt-ce-server all 5.12.0-1 [14.2 MB]
Fetched 14.2 MB in 4s (3,921 kB/s)
E: Failed to fetch https://packages.sury.org/php/pool/main/p/php8.4/php8.4-ldap_8.4.14-1%2b0%7e20251108.36%2bdebian11%7e1.gbpca7cb9_amd64.deb  404  Not Found [IP: 151.101.3.52 443]
E: Failed to fetch https://packages.sury.org/php/pool/main/p/php-defaults/php-ldap_8.4%2b97%2b0%7e20251117.58%2bdebian11%7e1.gbp8726a7_all.deb  404  Not Found [IP: 151.101.3.52 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Calculating upgrade... Done
  php7.4-xml
  linux-image-5.10.0-42-amd64 php-ldap php8.4-ldap
  libnghttp2-14 libpng16-16 linux-image-amd64 passbolt-ce-server tzdata
5 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 57.6 MB/71.9 MB of archives.
After this operation, 332 MB of additional disk space will be used.
Get:1 http://security.debian.org/debian-security bullseye-security/main amd64 tzdata all 2026b-0+deb11u1 [311 kB]
Get:2 http://security.debian.org/debian-security bullseye-security/main amd64 libnghttp2-14 amd64 1.43.0-1+deb11u3 [77.6 kB]
Get:3 http://security.debian.org/debian-security bullseye-security/main amd64 libpng16-16 amd64 1.6.37-3+deb11u4 [295 kB]
Get:4 http://security.debian.org/debian-security bullseye-security/main amd64 linux-image-5.10.0-42-amd64 amd64 5.10.251-4 [56.9 MB]
Err:5 https://packages.sury.org/php bullseye/main amd64 php8.4-ldap amd64 8.4.14-1+0~20251108.36+debian11~1.gbpca7cb9
Get:6 http://security.debian.org/debian-security bullseye-security/main amd64 linux-image-amd64 amd64 5.10.251-4 [1,484 B]
Err:7 https://packages.sury.org/php bullseye/main amd64 php-ldap all 2:8.4+97+0~20251117.58+debian11~1.gbp8726a7
Fetched 57.6 MB in 1s (51.6 MB/s)
Can you please help.
thanks
G’day Mike
There are two things in play here.
The sury.org signing key has expired on your server
You have the sury PHP repo configured so you can run PHP 8.2 on Debian 11 (bullseye only ships PHP 7.4 by default). That repo’s GPG signing key has expired, so apt update can’t verify the current package list and falls back to a stale cached index. That cached index references .deb filenames sury has since replaced, which is what’s causing the 404s. The sury keyring and the 404s are the same problem.
Refresh the key following the instructions in the sury README at https://packages.sury.org/php/README.txt. The shape of the fix is:
curl -sSLo /tmp/debsuryorg-archive-keyring.deb https://packages.sury.org/debsuryorg-archive-keyring.deb
sudo dpkg -i /tmp/debsuryorg-archive-keyring.deb
sudo apt update
Once apt update completes cleanly with no EXPKEYSIG warning, retry the upgrade:
Then run a healthcheck to confirm everything is in order:
sudo -H -u www-data /usr/share/php/passbolt/bin/cake passbolt healthcheck
Why is php-ldap being installed?
The 5.12 server package declares php-ldap as a dependency where 5.11 didn’t, which is why apt is asking to install a new package during this upgrade. Nothing for you to do about it, the install will go through fine once the sury key is refreshed.
My recommendation: move to Debian 13 trixie
The reason you need sury at all is that Debian 11 doesn’t ship a modern PHP. Debian 13 trixie includes PHP 8.4 in the default archive, so after a migration to trixie you can drop the sury repo entirely and this kind of problem doesn’t come up again.
There’s a CE server migration walkthrough for Debian 13 in the docs: https://www.passbolt.com/docs/hosting/migrate/server/ce/debian/
Cheers
Gareth
thanks,
will try it.
looks like key is invalid expired?
sudo apt update
Selecting previously unselected package debsuryorg-archive-keyring.
(Reading database ... 106439 files and directories currently installed.)
Preparing to unpack .../debsuryorg-archive-keyring.deb ...
Unpacking debsuryorg-archive-keyring (2025.11.18) ...
Setting up debsuryorg-archive-keyring (2025.11.18) ...
Get:4 https://packages.sury.org/php bullseye InRelease [6,136 B]
Get:5 http://security.debian.org/debian-security bullseye-security/main Sources [290 kB]
Get:6 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [454 kB]
Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [305 kB]
Err:4 https://packages.sury.org/php bullseye InRelease
Fetched 1,132 kB in 1s (1,032 kB/s)
12 packages can be upgraded. Run 'apt list --upgradable' to see them.
