So I upgraded to 2.12.1 today and it all works, exept when I run these commands, I get errors:
[bcgsupport@s201 public_html]$ composer install --no-dev
[ErrorException]
proc_get_status() has been disabled for security reasons
PHP Fatal error: Uncaught ErrorException: proc_get_status() has been disabled for security reasons in phar:///home/bcgsupport/bin/composer/vendor/symfony/process/Process.php:1279
Stack trace:
#0 [internal function]: Composer\Util\ErrorHandler::handle(2, ‘proc_get_status…’, ‘phar:///home/bc…’, 1279, Array)
#1 phar:///home/bcgsupport/bin/composer/vendor/symfony/process/Process.php(1279): proc_get_status(Resource id #310 )
#2 phar:///home/bcgsupport/bin/composer/vendor/symfony/process/Process.php(700): Symfony\Component\Process\Process->updateStatus(false)
#3 phar:///home/bcgsupport/bin/composer/vendor/symfony/process/Process.php(752): Symfony\Component\Process\Process->isRunning()
#4 phar:///home/bcgsupport/bin/composer/vendor/symfony/process/Process.php(167): Symfony\Component\Process\Process->stop(0)
#5 [internal function]: Symfony\Component\Process\Process->__destruct()
#6 {main}
thrown in phar:///home/bcgsupport/bin/composer/vendor/symfony/process/Process.php on line 1279
Stack trace:
#6 {main}
[bcgsupport@s201 public_html]$ ./bin/cake passbolt migrate --backup
/ / _ , / / / ./_ / /__/
Saving backup file: /home/bcgsupport/domains/bcg.support/public_html/tmp/cache/database/backup_1587108909.sql
Warning Error: exec() has been disabled for security reasons in [/home/bcgsupport/domains/bcg.support/public_html/src/Shell/Task/MysqlExportTask.php, line 124]
2020-04-17 07:35:09 Warning: Warning (2): exec() has been disabled for security reasons in [/home/bcgsupport/domains/bcg.support/public_html/src/Shell/Task/MysqlExportTask.php, line 124]
Something went wrong!
again passbolt is running fine on 2.12.1 it seems, but I am somewhat worried about the errors.
diego
April 17, 2020, 7:53am
2
Hi @pimzwager ,
Have you modified your php.ini?
Yes, I recently upgraded php, and for this to work I had to enable some modules.
diego
April 17, 2020, 8:24am
4
Probably that introduced the restrictions for composer.
You could just run composer with a temporary bypass of your php module restrictions:
php -d "disable_functions=" /path/to/composer install --no-dev
Same for the migrations command:
php -d "disable_functions=" /path/to/passbolt/install/bin/cake passbolt migrate --backup
sorry, I don’t understand much of composer, I get this error:
[bcgsupport@s201 public_html]$ php -d “disable_functions=” ~/public_html/composer install --no-dev
Could not open input file: /home/bcgsupport/public_html/composer
but he compuser is right there, right?
[bcgsupport@s201 public_html]$ ls
CHANGELOG.md Gruntfile.js README.md bin composer.lock index.php package-lock.json phpunit.xml.dist src tmp webroot
CONTRIBUTING.md LICENSE.txt app composer.json config logs package.json plugins tests vendor
diego
April 17, 2020, 8:35am
6
You should use the path to your composer binary.
You execute the command I posted from ~/public_html but the command should point to /usr/bin/composer or wherever the composer is installed.
For example:
cd ~/public_html
php -d “disable_functions=” /usr/bin/composer install --no-dev
You can identify your composer path using which composer usually
thanx, although I am still getting the error:
[bcgsupport@s201 public_html]$ php -d “disable_functions=” ~/bin/composer install --no-dev
[ErrorException]
Stack trace:
#6 {main}
Stack trace:
#6 {main}
remy
April 17, 2020, 8:47am
8
Are you using a 3rd party hosting provider? They may have disabled these functions. You may need to check with them if they offer some form of configuration panel.
yes we do. I have a configuration panel: DirectAdmin
what am I looking for to do?
remy
April 17, 2020, 8:50am
10
I’m not familiar with direct admin. I’d say check if they have some forms of PHP configuration options. You should find a text input with a list of disabled functions.
pimzwager:
proc_get_status
ahhh proc_get_status is listed as diabled. I should enable it?
should I restet this setting after my upgrade is done?
remy
April 17, 2020, 8:53am
13
pimzwager:
proc_get_status
Yes. It’s used by Symfony core packages, it’s safe to use in the passbolt context.
Exec is used also for the backups (--backup in migrate command) so either don’t use the option or enable it.
You guys are awesome! Thank you so much for your help!
Loading composer repositories with package information
Installing dependencies from lock file
Nothing to install or update
Generating optimized autoload files
Cake\Composer\Installer\PluginInstaller::postAutoloadDump
thadafinser/package-info: Generating class…
thadafinser/package-info: …generating class
App\Console\Installer::postInstall
Set Folder Permissions ? (Default to Y) [Y,n]? No Security.salt placeholder to replace.
Saving backup file: /home/bcgsupport/domains/bcg.support/public_html/tmp/cache/database/backup_1587113709.sql
Success: the database was saved on file!
Running migration scripts.
using migration paths
/home/bcgsupport/domains/bcg.support/public_html/config/Migrations
using seed paths
/home/bcgsupport/domains/bcg.support/public_html/config/Seeds
using environment default
using adapter mysql
using database bcgsupport_passbolt
All Done. Took 0.6644s
Cleared default cache
Cleared cake_core cache
Cleared cake_model cache
system
Closed
April 22, 2020, 8:55am
15
