Event based OTP
We do have time based otps already. But these do not allow for us to use event based otps.
Q2 - Who is impacted?
Almost everyone that is deep in the IT world will at some point encounter the need to save an event based otp
event based otps are important for some authorizations. Sure, time based ones are generally better and more secure but not every application/web site supports them.
I would like to be able to add an event based otp to an account (not just totp)
Can you clarify what you mean by event based OTP, do you mean HOTP?
Do you have an example of device or app that uses that.
