Exception: Class ´Cake\Mailer\Transport Factory'
At the moment of running the update script this error appears:
Exception: Class ´Cake\Mailer\Transport Factory’ not found in [var/www/passbolt/config/bootstrap.php, line 141].
does anybody know how I can fix it?
I am upgrading from 2.7.1 to 2.12.0
Hi @leinax,
Have you run the command composer install --no-dev before running the migration?
If not, please try to run the command composer install --no-dev from your /var/www/passbolt directory and then to start the migration process again.
Let us know if it works or if you encounter any issues.
Maxime
