Exception: SQLSTATE[HY000] [2002] Connection refused
[PASS] PHP version 7.0.33-0+deb9u7.
[PASS] Full base url is set to https://pwd.lxxx.fr
[PASS] 24 tables found
[PASS] Using latest passbolt version (2.12.1).
Hi all,
I’ve installed Passbolt in 2018 from 1.0.12 on a Debian 9, and followed the life project till 2.12.1 …
The system works perfectly, a real pleasure to use. Didn’t find any problem during the use, but, since severals weeks, i receive mail notifications from my Passbolt Server
(su -c “/var/www/passbolt/bin/cake EmailQueue.sender >> /var/log/passbolt.log” -s /bin/bash www-data):
Exception: SQLSTATE[HY000] [2002] Connection refused in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 92]
su: Cannot make/remove an entry for the specified session
I don’t understand why, and what are the consequences ?
Could you please give me some help ?
Best regards
Hi @vig
Thanks for your kind words about passbolt! We really appreciate them.
Let me understand one thing about your message. The error you posted comes from manually executing su -c “/var/www/passbolt/bin/cake EmailQueue.sender >> /var/log/passbolt.log” -s /bin/bash www-data ?
Hi Diego,
Thank you for your quick reply,
this command is executed by a cron every minute to send mail.
Sorry I think there is a misunderstanding. What I meant is have you tried to run that command manually and check if you get an error?
Considering the healthcheck log you posted where the database connection seems to work it looks like the environment when executing the cron job has some problems.
oh sorry,
yes i tried to run it manually, and didn’t get any error. It appear only with Cron.
Do you think this is a False Positive error message ?
Hi @vig,
Which user is running the cron job?
Hi Diego,
This is ROOT Cron job.
Considering the su message you see let’s try try the following:
Define a system wide cron job in /etc/crontab like this:
* * * * * www-data /var/www/passbolt/bin/cake EmailQueue.sender
Of course disable your old cron job :smiley:
Thank you very Much for your help Dear Diego.
I’m going to test this solution.
I will keep you in touch.
Cheers
so, i did the modification with www-data cron job.
Now i’m getting this error :
PHP Notice:  PDO::__construct(): send of 119 bytes failed with errno=32 Broken pipe in /var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php on line 92
Exception: SQLSTATE[HY000] [2006] MySQL server has gone away in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 92]
Regards
It is a bit weird your issue,
Could it be there is no enough memory on the server for your setup?
Do you have any mysql error log?
The server is big enough, with 8 Go of Memory and huge free disk space.
About MySQL Error, nothing .
Which user is supposed to own Driver.php ?
If you run on debian nginx and apache should use www-data as user to run. So the www-data user should be able to read and execute most of the passbolt files.
Some of these files www-data requires permission to write such as the files under the /var/www/passbolt/tmp directory, the logs and the public images directory /var/www/passbolt/webroot/img/public
Easiest solution is to make www-data owner of all the passbolt files.
Hi Diego,
How are you doing ?
So i’ve check permission, everything is ok, files are owned by www-data.
Still have 3 or 4 error messages per day.
Warning Error: PDO::beginTransaction(): MySQL server has gone away in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 184]
 2020-04-29 23:25:37 Warning: Warning (2): PDO::beginTransaction(): MySQL server has gone away in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 184]
Warning Error: PDO::beginTransaction(): Error reading result set's header in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 184]
2020-04-29 23:25:41 Warning: Warning (2): PDO::beginTransaction(): Error reading result set's header in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 184]
Exception: SQLSTATE[HY000]: General error: 2006 MySQL server has gone away in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 184]
There is no error in mariadb logs.
I don’t have any idea.
Could it be your datbase server having issues?
https://dev.mysql.com/doc/refman/8.0/en/gone-away.html
