hi, when i go to http://xxx.xx.xx.xx/auth/login? It asks me to install the plug in and I proceed to install it once the extension has been added, I go back in and it asks me again to install the plug in
Hi @fabiovega
and welcome to Passbolt community forum
It is an old bug who has been fixed, are you running the last Passbolt version ?
And also which Chrome version are you running ?
Best regards,
Hi I have the same exact issue.
Google Chrome Version 96.0.4664.93 (Official Build) (64-bit)
Hi @andgatt
Which Passbolt version are you running ? You can mouseover the heart at the bottom right of the Web UI to know it.
Hello !
I have the same issue.
The passbolt version that I am using is the 3.4.0, (while the last tag on the repo Releases · passbolt/passbolt_browser_extension · GitHub is the 3.3.1).
And I am using chrome version 90.0.4430.72 (Official Build) (64 bits).
PS: The passbolt browser app is the one coming from here: Passbolt - Open source password manager - Chrome Web Store
Thanks @max for the answer.
But I am seeing a screen that is only offering to download and install the plugin. (While it is installed and present in the extensions of my browser). Sooo, I am in neither cases. ^^’
I checked on firefox, and I don’t have this issue, everything works as previously. It is only present with chrome.
EDIT: Another colleague tested, and it is not working neither on firefox, nor on chrome.
Can’t give you the version as since I have the extension installed it is showing to install again. Can’t access passbolt.
My issue is fixed…
It was just a matter of using the correct link with the token in it, instead of trying to directly access the passbolt instance.
Sorry for my noise.
I’m also having this same issue, chrome Version 96.0.4664.93 (Official Build) (64-bit)
removed and added passbolt
localhost:9099/auth/login asks for plugin to be installed even though it is.
Clicking the plugin in the extension bar just takes me to your homepage.
@Matt11 If you are running an API v2.x with the latest browser extension, this is an expected regression. The home page of the application has evolved and the legacy API v2.x home page doesn’t display the link to recover your account anymore.
You have 2 options:
- You can go to https://localhost:9099/users/recover and request a recovery token. You will then receive an email with a link to follow to initiate your account recovery.
- You can update your API to the latest version, the online documentation is complete and will guide you step by step: Passbolt Help | Upgrade
Same issue seems happening now.
I’m using Passbolt Chrome Extension v3.5.0.
Yesterday (2022 Mar 20) Chrome updated to 99.0.4844.82, and I cannot login to my admin account.
I tried to recover, but it stuck at the extension checking page.
I have the extension. It kept asking me to install the extension and refresh.
Any thing I can do?
Hi @leon ![]()
Did you try to clear your browser cache and cookies ? => chrome://settings/clearBrowserData
Thank you for your feedback,
2023 June,
Having the same issue here with the initial installation.
I am trying to login with the Admin account with no joy.
Chrome version: 114.0.5735.134 (Official Build) (64-bit)
Firefox version: 114.0.2 (64-bit)
PassBolt: latest docker version
Php: 7.4.33.
Tried:
- Clearing cache and everything from chrome - Unsuccessful
- Removing and adding the extension again - Unsuccessful
- Using the URL generated from bash when creating the user - Unsuccessful
- Using the login when opening the site and adding the email address to receive a confirmation - Email received, stuck on the same extension error - Unsuccessful
- Checked User cannot signing after v3.6 upgrade - Docker and I only have 1 instance.
Please can someone advise? Thanks.
Healthcheck report:
[PASS] PHP version 7.4.33.
[PASS] Full base url is set to https://MYURL
[HELP] cURL Error (60) SSL: no alternative certificate subject name matches target host name 'MYURL'
[PASS] 30 tables found
[HELP] you can try:
[FAIL] This installation is not up to date. Currently using 3.12.0 and it should be v4.0.2.
SMTP Settings
[FAIL] 6 error(s) found. Hang in there!
Currently trying to fix the errors mentioned in the health check report.
when you removed and readded the extension did you do that directly from the extension manager page?
If so try removing the extension, going to the URL and clicking the download extension button on the page from your screenshot
This is exactly how I did it without any joy. The extension installation page returned soon after.
I run the healthcheck and for some reason the latest docker image pulled v3 instead of v4. I will check with v4 if this happens and will update the query.
For some reason the docker:latest downloaded v3. I started with a fresh install specifying v4 and it solved the issue.
